Question about Pioneer AVIC-Z1 Car DVD Player
Humming sound I installed a 400 watt amp and it was working for about10 seconds and then the sound went out and a loud humming/buzzing sound comes on as soon as the car is turned on. I think the amp may have overloaded the system. Any thoughts?
You might need a surge suppressor i think that what its called i had a problem like that with one of my old cars the noise is generated from the engine and it goes through the power creating a surge which makes it hum cause the power needs to get filtered properly. you conect it in the positive and negative wires
Posted on May 09, 2008
Sony stacking system LBTd505, the sound from the record deck suddenly went very faint. The cd and radio sections are fine. I have tried a new stylus, but no difference. Any ideas?
You have two options. First a faulty cartridge. Or a faulty pre-amp in the main amp.
You can find out if the cartridge (and amp) are playing up. By removing the connectors on the cartridge.
Then with the volume turned up to about half, with your finger, touch each one of the wires one at a time. It will not harm you at all. But you should hear a loud buzz on one wire on the right and a loud buzz on the left on another wire.
The two other wires will either produce a crackle, or a tiny buzz, or nothing at all.
If you do hear a loud buzz on two wires. The cartridge is faulty and needs replacing.
If you hear a slight buzz on them or weak sound. There is either a bad connection between the deck and amp. Or the pre-amp inside the deck which is only used by the record deck so will not effect any other function, is faulty.
You can remove the record deck connections to the amp and again with the amp on half full, touch the inputs with your finger. If you are not hearing a loud hum or buzz, the pre-amp is faulty. If you do the connectors are faulty.
Jun 11, 2016 | Sony Audio Players & Recorders
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Only humming or buzzing , no music or sound
Try different cables. That would be the most simple and cheapest fix.
May 27, 2014 | Roland Kc-150 65-watt Keyboard Amplifier...
Loud humming noise from under my Tahoe. 2WD
The noise is your fuel pump which should hum, but not buzz. It is going bad & will need replaced soon.
murf427
Aug 02, 2012 | Chevrolet 2001 CHEVROLET TAHOE Chassis...
Bugera 333xl every few seconds there is a loud buzzing. from
It looks as though you have ripple noise that amplifies into the output. First of all check if the mains voltage is going down to produce the low voltage hum. If not you will have to check the DC filter capacitors , couple in parallel to confirm the capacitor. IF the buzz is still coming through then you will have to isolate the preamp and wait it the fault is coming in. If not connect the preamp output to another amp to hear the same buzz to confirm the preamp to be faulty. If so you will have to trace by a voltage check when the buzz occurs to confirm if the preamp IC or the selector Ic is faulty. Some logic IC's can also produce this noise on static switching. If teh noise is appearing on both the channels, then I would still bet on the power section. So check once again on the rectifier/ regulators and capacitors. Hope this advice helps. Good day
May 16, 2010 | Audio Players & Recorders
Dryer making a buzzing noise
It sounds like your motor has gone bad....it will buzz or hum when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 13, 2010 | Frigidaire Electric Dryer
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
Nothing but loud buzzing coming over the amp when trying to play. Any suggestions?
If the buzz disappears when you unplug the cable from the amp. check your cable.
If the buzz disappears when you unplug the cable from the instrument, there's something thay may have come loose inside the instrument.
If you unplug the cable from the amp., and the buzz persists, you'll have to have a competent tech. check your amp.
Apr 14, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Constant Humm / Buzz but Works OK
I was going to suggest the low voltage transformer, but when you said it sounded like it was coming from the left side, that seemed odd. I have a stock transformer here I keep for test that is loud, but it works. Odd, eh?
Dec 21, 2006 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Pioneer AVIC-Z1 Car DVD Player Logo
532 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
