Question about Refrigerators
Super slow water pressure from GE Profile refirgerator
The water pressure coming out of the external water dispenser has become increasingly slower, and it's also impacting the amount of ice being made. Any suggestions?
  • 115 Answers
Filter needs to be changed it is in the refrigerator side in the top back right hand corner
Posted on Dec 30, 2008
Inside water dispenser pumps water out really slowly on GE Profile PFS22MISBBB
It is possible that your water filters are getting plugged. Have you changed any filters lately?
The meat pan lever may also be turned to the coldest position and on units that have a low water usage, this will also cause the tank to freeze. You will want to lower the meat drawer setting or use more water from the door. This does not apply to Top Mount water dispenser models, because they do not have a reservoir. Problem requiring service, glass fill time.
View a short video about troubleshooting water dispenser issues :
Play Video
View a short video about slow water dispensing issues:
Play Video
  • Dispenser drips water constantly will be a water valve problem, and should be checked by a service technician. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
  • Dribble as defined as a small amount of water (few drops) that may miss the glass ONLY AFTER USAGE. This is due to a delay in the overall system.
    Dribble can be minimized by the following actions:
    - Purge the tank, by holding down the dispenser for 2 to 3 minutes, to remove any trapped air that may be building pressure and causing the dribble.
    - A few drops is normal, but you can also prevent water from missing the glass and dripping down the cradle area by moving glass slower when removing it from the cradle.
    - You may need to periodically empty the recess grill and clean out underneath it to prevent overfilling and water dripping down the front of the refrigerator.
  • Also, remember the dispenser in the door will not operate unless the door is closed
  • Apr 10, 2012 | GE Refrigerators
    Water dispenser in the freezer door has a constant slow drip, how do I fix it?
    You will need to replace the water valve. It is located in the back rear of refrigerator. If it is leaking by then you will see drip. Before you replace valve make sure the water pressure of water supply is proper. The valves will not seal properly without proper pressure.
    Nov 24, 2010 | GE Profile Arctica 25.4 Cubic Feet...
    Decreased water flow from dispenser GE GSS25WGTA refrigerator
    This is usually caused by the water inlet valve not opening all the way or it got clogged up. The valve assembly will need to be replaced, don;t try cleaning it out it will likely cause a clog further up the tube. They are usually pretty inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/referwaterinlet.html
    Jun 23, 2010 | GE Refrigerators
    GE Profile PSS26PSTA SS freezer problem
    Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
    If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
    Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
    Ge profile refrigerator slow water dispenser
    you have a seperate valve for ice maker and water dispenser, though it is possible both could have debris preventing proper water flow, i would check the water pressure you have going into the valve solenoid housing. turn off water to fridge, disconnect the line at the fridge, not in basement at saddle valve. place end of tube in bucket, turn on water. how is pressure? good or slow? if its good, then you probably do need to replace valve solenoid housing. You can NOT clear debris out of these, they must be replaced.
    If your water pressure is still not good, either y ou have a kink in plastic water line. Despite having changed saddle valve in basement, if the stem of saddle valve is mounted on bottom half of pipe, debris from pipe is getting into water line and so on. You can reply here or send me a question from my website: www.FixMyFridge.net
    Mar 15, 2010 | Refrigerators
    Ge profile arctica side by side- ice maker and water dispenser not working..have already replaced the water filter
    The water dispenser and the icemaker both operate on different soleniods on the water valve so the chances of a bad valve are slim. I would assume you issue is in your water supply. The easiest thing you could try first would be to check your saddle valve that taps into your main water line to supply the ref. They are known for calcium deposits which obstruct the flow of water. This issue is IDed by very slow water pressure through th door. If its gunked your icemaker fill tube may also be frozen.
    Jan 11, 2010 | GE Profile Arctica Stainless Steel Top...
    How to increase water dispenser pressure
    I've found that the dispenser pressure is directly related to the position of the water supply valve. If the shut off valve at the house water pipe that supplies water to the frig is not open completely or is partially blocked, you will get poor pressure at the dispenser. Open the valve more or replace it.
    Nov 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    I have a side by side GE refrigerator and the water dispenser is leaking quite a bit. It looks like is leaks where the water is dispensed.
    Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
    Oct 31, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Ice maker stopped working w/red light blinking
    The blinking light is an indication that your built in water filter needs to be replaced, it's in the refer. side, middle top or rear of refer.
    May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    Refrigerators Logo
    387 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
