Question about Dell Dimension 8200 PC Desktop
How to add memory to dell dimension 8200
I own a dell 8200, how do I add memory to speed it up?
  • 42 Answers
Http://www.tigerdirect.com/applications/category/memory_config.asp?ClsId=100
Enter the following information in the blank
and you should come up with which ram is compatible with your computer
then refer to this link on how to install the ram into your computer
http://static.tigerdirect.com/html/guide_installing_desktop_memory.html
Posted on Dec 30, 2008
What memory (does) it use?
Jokodi Haynes,
The Dimension 8200 memory specs are listed below.
Memory
Architecture RDRAM
Memory connectors four
Memory capacities 64-, 128-, 256-, and 512-MB non-ECC RDRAM
Minimum memory 128 MB
Maximum memory 2 GB with Microsoft® Windows® 2000 and Windows XP; 512 MB with Windows Millennium Edition (Me)
Memory type PC800 (non-ECC)
Memory speed 40 ns or faster
BIOS address F8000h
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 29, 2016 | Dell Dimension 8200 PC Desktop
What is the maximum ram capacity of dimension 8200 motherboard
2 gygabytoes are usually the max, you could upgrade the OS to maybe Windows XP 64 bit, but this isn't worth it in such an olde machine! Throw it out and get yourself an ASUS laptop with Windows 7 64-bit, a solid state HD and 4 or more gigabytes of ram instead!.
http://www.crucial.com/upgrade/Dell-memory/Dimension+%2F+Dimension+XPS/Dimension+8200+Series+%28400MHz+FSB%29-upgrades.html
Mar 16, 2013 | Dell Dimension 8200 AUD System Board...
What size memory card do i need for a dell 8200
the size of your memory card may be of any length but be sure that your system supports it
thanks
May 14, 2010 | Dell Dimension 8200 PC Desktop
I am getting ready to intall additional Rambus memory to my Dell Dimension 8200 and need walked through it... Any help?
Hello d_silverthor,
Here's a video link shoing how to install memory in a Dell Computer:
http://www.memorystock.com/memory/viewvideo.asp?systemtype=Dell+Desktop&Class=Desktop
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | Dell Dimension 8200 PC Desktop
I want to add more ram. Where do I get it? Dell
I hate to be the bearer of bad news, so don't 'Shoot the Messenger'!
The Dell Dimension 8200 Desktop PC uses RDRAM ram memory.
VERY expensive stuff!
Supporting Data:
This is Dell Support, Manuals, and the Dimension 8200 Service Manual,
http://support.dell.com/support/edocs/systems/dim8200/
Scroll down the list to the heading - Specifications, and left-click on it.
Scroll the page down until you come to the heading - Memory
Now look at the first subheading - Architecture
RDRAM
You have 4 ram memory slots. (memory connectors)
EACH, ram memory slot can support up to a Maximum amount, of 512MB. (512 MegaBytes)
TOTAL Maximum Amount for your computer is 2GB. (Not shouting)
1024MB = 1GB. (1024 MegaBytes = 1 GigaByte)
The type of Rdram ram memory is PC800, and it is Non-ECC.
(Error Correcting Control, or also stated as Error Correcting Code.
Used mostly for Server computers. Your computer does not use ECC ram memory)
In My Humble Opinion, (And again, don't shoot the messenger), it would be better money spent to buy a decent affordable computer, than it would be to upgrade the ram memory in this computer.
This statement is based upon the fact that the Dell Dimension 8200 ships with 128MB's of ram memory.
(Makes it a pretty slow computer. Rdram or not)
The average cost to install, for example, 1GB of ram memory is OUTLANDISH! (Not shouting)
Example 1:
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=24927
Example 2:
http://www.pcmemorystore.com/Dell-Dimension-8200-ram.htm
For about another $100 you can buy a pretty decent new desktop computer, that will run the one you have in circles.
Just my thoughts.
Dec 07, 2009 | Dell Dimension 8200 PC Desktop
Trying to find the Jumper that controls FSB on a dell dimension 8200. Either that or some form of overclocking software that will allow me to get the full 2.8 out of my P4
modern Boards Auto-Detect FSB speeds, usually determined By CPU fsb And Memory/Ram speeds. It may be Wise to see if theres A user manual/guide for this board. or a possible bios update to support the CPU. also check the boards fsb speed ratings charts. overclocking is not recommended, as this can damage cpu/ram and motherboard.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension 8200 PC Desktop
Possibility of using Dimension 8250 memory in a Dimension 8200
Probably not, but to confirm go to this link. When you're there plug in the info for both machines and compare the memory configurations.
May 25, 2009 | Dell Dimension 8250 PC Desktop
Can Dell Dimension 8400 intel celeron work with 3 gig ram
Yes it can but try to match up at least two, to gain the advantage of dual channel and when you buy your extra ram, check that it matches the other two that you have in size, speed and technology (like 3x1G DDR2 same speed). Also you may have to play with which slot to put the third one but I had this one run with three modules before yes.
Otherwise your Dell Dimension 8400 can see upto a maximum of 4.0 GB memory, with maximum of 1GB per slot in 4 (2 banks of 2) memory slots.
Feb 14, 2009 | Dell Dimension 8200 PC Desktop
Hi Have a Dell Dimension 8200 trying to increase memory Original is 2x128 plus 2xcontinuity Purchased 2x256 and installed but computer will not work.Is it the case that I can only install another 2x128...
On a Dell Dimension 8200 there were 2 available bus speeds, 400mhz and 533mhz. The bus speed determines the required RAM speed. Most common 8200's have a 400mhz fsb and require a RAM speed of 45ns or faster (Lower number = faster). Some 8200's have a 533mhz fsb and require a RAM speed of 40ns or faster. The RAM modules must be installed in matched pairs, but the 2 pairs do not have to be equal to each other. (I have 8200 with 2x512mb and 2x64mb - you can also mix ECC and NON-ECC pairs but it will disable ECC) Check the last 2 numbers on your original RAM that works in your system, they will be either 40 or 45. If they are 40 - and 45's won't work, you have a 533mhz fsb. If this is the case, buying the same RAM in a 40ns speed will solve your problem...... Hate to be the one to break it to you, but if you do need 40ns (Rambus) RAM, it is very expensive - about 4 times the price and 1/10th as common as 45ns RAM. Some good deals can be found on ebay - search: rambus 40ns.
Hope this helped, and good luck :)
Jul 16, 2008 | Dell Dimension C521 PC Desktop
Dell Dimension 8200 Processor
hi, i also hav a dimensions 8200 which i recently uprgaded to a 2.8gh, but i discovered there were two versions of this system one which supports a 400FSB and the other 533FSB, these can determine the speed of ur cpu. Like you, I havent been able to unlock my clock speeds in the bios but i think you should be able to get more from ur new cpu by updating ur bios version to A09. check the dell site for more info on how to do this.
Apr 25, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
211 people viewed this question
Alun Cox
