Question about American Standard 6723S 'The Standard Collection' Toilet Tissue Holder - Sa
Installation what do I use to mount the holder? Hardware is not provided and there are two oval holes. What type of screw do I need and where do they go?
  • 334 Answers
If you are going into drywall then a threaded drywall anchor like this
Will be best.
Yopu can buy them at any hardware store. They screw right into the drywall and then another typical screw goes through the mounting plate into this anchor.
I recoment getting metal anchors as the plastic ones break easily.
These hold MUCH better than the push in plastic anchors.
Posted on Dec 30, 2008
Need mounting instructions and template
The first thing to do is to determine which mounting posts should be installed into the case Locate the holes in the motherboard, and hold the motherboard over the case and see which of the predrilled holes line up. Screw in or snap in the posts/holders in those holes. Remove any posts/holders where they do not line up to the holes in the motherboard; they will cause shorts and damage/destroy the motherboard. Snap in the template into the rectangular hole, and insert the motherboard into the case. Screw in the screws. Do not overtighten!! Connect the cables, and you are done. (This assumes the memory, processor, and cooler were preinstalled on the motherboard)
Aug 26, 2015 | Computers & Internet
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
I have a franklin towel bar and the mounting bracket broke at the screw hole. is there replacement mounting brackets avaible?
Probably not, but if they sell a toilet paper holder of the same style the bracket might be identical to the towel holder, but would be cheaper than buying a new towel bar. Good luck, Al K
Mar 16, 2011 | Franklin BATH UNLIMITED NORTHPORT TOWEL...
Need to remove center console to replace seat belt. After removing 12 screws, console is still firmly in place. What else has to be done?
  1. Remove the two oval covers from the sides of the floor console. Remove the four (two on each side) retaining bolts. Lift or remove the front seat center armrest from the floor console.
  2. Remove one screw from the top rear end of the floor console (directly under the front seat center armrest.
  3. Remove four screws retaining the utility tray beverage holder to floor console. Lift or remove the utility tray beverage holder from the console.
  4. Remove two screws (directly under the utility tray beverage holder) retaining the front end of the floor console to the console panel front mounting bracket.
  5. Lift the floor console from the front and rear console panel mounting brackets.
Feb 27, 2011 | 1996 Ford Explorer
How to remove towel bars and hooks from wall. No set screw visible. We did not install them.
Newer towel bars don't have set screws... Solution-slide off! There is an opening in the bottom of the bracket. Slide your flat head screw driver inside the opening and place pressure on the bottom. Make sure you place enough pressure to allow the holder to slide off.. Now pull on the holder and it will snap off...
Sep 23, 2010 | Moen 24 In. Towel Bar...
Center console disasembly instructions . we are trying to remove the center console
Base Console, Floor, Ranger, Explorer Removal and Installation
  1. Remove the two oval covers from the sides of the floor console. Remove the four (two on each side) retaining bolts. Lift or remove the front seat center armrest (644A22) from the floor console.
  1. Remove one screw from the top rear end of the floor console (directly under the front seat center armrest.
  1. Remove four screws retaining the utility tray beverage holder to floor console. Lift or remove the utility tray beverage holder from the console.
  1. Remove two screws (directly under the utility tray beverage holder) retaining the front end of the floor console to the console panel front mounting bracket.
  1. Lift the floor console from the front and rear console panel mounting brackets.
Apr 01, 2010 | 1996 Ford Explorer
I have a 37
Metric M5 screws, the wall you buy will be supplying with mounting hardware.
http://www.toptvmounts.com/
http://www.mountsdirect.com/
http://www.mountsmadesimple.com/
Just Google " wall mount for xxxxx"
Nov 24, 2009 | Televison & Video
How to remove the mounting flange from a circular, one-arm toilet paper holder, so it can be re-mounted? there is no set screw to release it-- the flange has two screw holes on either side of a center...
you will need a vary small flat screw drive and at the bottom of the holder the is a small hole insert screw driver and un screw, it has a small screw that holds to the plate on the wall
May 05, 2009 | YORKSHIRE 5308 - Yorkshire Paper Holder -...
How to Install Towel Ring
Place the mounting bracket against the wall and trace around the inside of the two ovals on the bracket. Gently drill a hole into the center of the traced oval. If you hit a stud, you will not need the anchor. Carefully tap the drywall anchors into the holes. Screw the bracket onto the wall, using the screws provided, into the two anchor points. Make sure the set screw is backed out far enough to set the escutcheon over the mounting bracket. Place the escutcheon over the mounting bracket, top first. Tighten the set screw with the Allen Wrench provided.
Aug 27, 2008 | Kohler Bathroom Accessory Set with Classic...
PRESTIGE CB130
On Prestige Combi Microwave the bub is on the control panel side. First remove the cover, Philips and torx required to remove screws on the back. *** MAKE SURE MAINS PLUG PULLED OUT ***
Looking at at the magnetron unit, find a black oval shape between it and the control panel with two wires plugged in, there are two bend strips holding the bulb holder in (this is directly behind the vent holes on the right hand side of the microwave oven), straighten them and extract holder with bulb, swap bulb with same rating and reverse the operation and re-assemble.
Jul 27, 2008 | Microwave Ovens
American Standard 6723S 'The Standard Collection' Toilet Tissue Holder - Sa Logo
106 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
