Question about JVC MX-KB4 CD Shelf System
Display will not work. All other function work.
DISPLAY WILL NOT LIGHT UP. ALL OTHER FUNCIONS WORK FINE. CANNOT TELL WHICH MODE OR STATION YOU AR ON.
You will need to just get another system.
Posted on Dec 30, 2008
How do I tell if a relay ,switch, or capasitor?
all pushing down on the relay tells you is that the power supply ,and the motor ar good , your problem is inside the control station
Feb 29, 2016 | Health & Beauty
Light on in fridge but neither fridge or freezer working at all.
Have the thermostat checked and the compressor for functionality. If the motor /compressor does not work at all you will not be able to tell if there is insufficient coolant in the system. If the compressor funcions it may be the thermostat or the coolant level .
Can you tell us whether the compressor comes on at all please
Aug 09, 2015 | Refrigerators
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
My AR-M205 Sharp Copier is not functioning and has an L-6 flashing indicator light in the display. Can you please tell me what this means and how I can fix it? Thank you.
Thats not a good code. Polygon motor lock. Theres a mirror in the laser unit that spins. It could be as simple as a connections is lose or the laser unit has gone bad. There is no easy way for you to fix. Will probly need to contact a service tech.
Aug 24, 2010 | Sharp AR-M205 Copier
The display went out on the radio/cd player of our 2005 Mazda 3. The decorative light works by the volume knob but we cannot tell what station the radio is on or any of the functions because of the lack of...
this happened to me after 2 years of having my 2006 Mazda 3, luckily i was still within warranty. the entire LCD had to be replaced in mine
May 12, 2010 | 2006 Mazda 3
I have a new ESTR 200 that has been in a closet for a couple of years. Very little seems to function well. The presets will not hold if I turn the system off or if I turn to another function. Record...
I assume we're talking about the Element ESTR200...
A turntable will not work with this receiver unless the TT is already preamplified. No Phono Preamp in this unit.
Presets:
From the manual...
Store a station
1. Press the FM/AM button on the front panel (or
the AM/FM button on the remote).
2. Select the station you want to store in memory
by the methods described above.
3. Press the MEMORY button on the remote
While "MEMORY" is glittering, press number
buttons on the remote for the station.
If the Memory indicator on the display turns off before you preset the station selection, Press Memory again.
Manual preset
1. Select the band wave by pressing FM/AM
repeat.
2. Turn to a radio station(see "Manual tuning" on
page 8 in details).
3. Select a group (A- D) of preset stations. This
group will be displayed on the front panel.
For example: "A".
4. Press MEMORY on the remote control.
"MEMORY"will appear on the display.
5. While the word "MEM" appears, input your desired preset number (1-8 ) by using the numeric keys on the remote control to store the radio station. For example this number is "1", the station is stored as "A1".
NOTE:
A new setting can cover the former one.
This memory is kept before next reset.
Retrieving preset stations
1. Press FM/AM button on the front panel or the
remote control to select tuner mode.
2. Press A/B/C/D button on the front panel or the
remote control to select the group of preset stations that you require.
3. Press the numeric keys on the remote control to select the number of preset station that you require. Station selected is displayed on the front panel.
4. By the same way, you can select other stored
stations.
The remote control does not operate the unit.
-Another function is selected on the remote.
Press the correct function button.
-No batteries installed. Install the batteries before
using the remote.
Be sure "+" and "-" marks of each battery match the symbol on the inside of the remote battery compartment.
-The batteries are exhausted. Replace all batteries.
-The remote is not pointed at the remote control sensor on the main unit or there is an obstacle between the remote and the main unit.
-The remote control is too far away from the main
unit, move closer.
Dec 05, 2009 | Audio Players & Recorders
Ar-160 display says "check panel" no more codes or functionality
tis problem is some of panel button is short i mean it is lock please open your machine panel board and service it . then solve your problem
Aug 02, 2009 | Sharp AR 201 Copier
Bridge II only displays Album title
I had the same problem with my HK AVR 355 and The Bridge II.
Yours has entered manual mode by itself?! You think the bridge it did by itself but You did it.
I tell you how! I had the same problem but it's not problem but a lack of user's manual. In the automatic mode the searching through albums and artist on the on screen display is very slow. You are pushing and pushing and pushing the "menu" button. That was the problem!
Connect your bridge and ipod and turn on the AVR. Switch to The Bridge as input. It will say that you are in manual mode. Push the menu button on the AVR's remote for a few seconds. And it will turn back to automatic mode!!! That's all!
The real problem is neither of two manuals (The Bridge and AVR) tell any words about the function of holding down for seconds the menu button. Its function is to switch between manual and automatic mode!
Feb 21, 2009 | Harman Multimedia Harman Kardon...
How to operate function keys and right click in intel dot station keyboard
F1 = HELP F2 = RENAME SELECTED ITEM, F3 = SEARCH FOR FILE OR FOLDER, F4 =Display the Address bar list in My Computer or Windows Explorer, F5 =Refresh the active window. F6 = Cycle through screen elements in a window or on the desktop. F7 =Displays all commands for this program stored in memory in a pop-up box. Use the UP ARROW key and the DOWN ARROW key to select the command you want, and press ENTER to run the command. You can also note the sequential number in front of the command and use this number in conjunction with the F9 key. , F8 =Displays all commands in the history buffer that start with the characters in the current COMMAND , F9 =Prompts you for a history buffer command number, then displays the command associated with the number you specify. Press ENTER to run the command. To display all the numbers and their associated commands, press F7., F10 =Activate the menu bar in the active program, ALT+F10= Deletes all macro definitions.
UZOWUANYA
e-mail: uzowuanya@yahoo.ca
Feb 11, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
JVC MX-KB4 CD Shelf System Logo
227 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
