Question about Maytag Dryers
The dryer won't turn on
About 2 weeks ago, during drying the dryer would stop eventhought the clothes weren't finished. I would leave the door open, return about 1/2 hour later and it would turn on. As days went on the dryer would stop after about 10 min, then 5min. Now it woun't turn on at all. When you push the button it sounds like it wants to start, but won't. the drum is turnable. I called maytag and they give me an estimate. Then to get the estimate you have to pay a huge fee.
  • 1 more comment
  • allhousemail Dec 30, 2008
    That's exactly what I thought. We pulled the dryer apart last night, cleaned the motor and the dryer lasted about 10 min. I found a new motor pretty reasonable. So, I think I will order it. If you still want the model number it is PYG1000AWW.
    Thank you
    kim
  • allhousemail Dec 31, 2008
    Thank you : )
    Thank you : )
  • 640 Answers
Drive motor defective ,,,i can walk you thought,,,but i need a model number
Posted on Dec 30, 2008
  • onthethejob1
    onthethejob1 Dec 30, 2008
    if you need any back up help,,im here happy new year..
  • onthethejob1
    onthethejob1 Dec 31, 2008
    happy new year,,im onthejob if you need me...
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
GE dryer heavy duty 7 cycle, just finished drying a load of clothes, put wet ones in and closed the door turned to the cycle i wanted turned the start switch and nothing.... but a light hum...
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Sep 27, 2011 | Dryers
Smells musty and not washing clothes well
"In washing in the HE washers I think that if you have more than 3 loads a week you should maybe wash your washer at least once a week. I have started wiping the door off and leaving it open between washing and that helps a
lot with the smell.
This is why I think if you could wash the washer once a week it would probably do better. You never had this problem in the old washers." Try this in your washer.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer turns off before cycle finishes
if unit has auto temp control,you may have a bad thermistor,,,,,make sure door is latching tightly,could be pushed open during cycle stopping it
Mar 03, 2010 | Whirlpool LER5636P Electric Dryer
Dryer not drying
You have a venting problem and air is not leaving. Its either kinked or clogged.
Mar 29, 2009 | Dryers
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Unit will not turn on at all. Power source definately works. Unsure if unit stopped during dry cycle or finished and never came back on, but clothes were dry, indicating it was finished with the wash...
Sounds like the problem is with the control board.  There is an internal fuse in the board but it is not replaceable.  You will need a qualified LG technician to service this unit.
Nov 03, 2006 | LG WD-3245 Front Load Washer / Dryer
Dryers Logo
77 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
