Question about Kodak EasyShare DX4530 Digital Camera
Cannot format memory card
After I inserted new card, it says that memory card required formatting....I hit Continue...it warn me that formatting will delete everything on the card......i hit continue...it says "formatting" and shows an hourglass icon...then AGAIN says memory card requires formatting. How do I format ?
  • 1 more comment
  • Anonymous Jan 19, 2009
    I have same problem
  • Deeshelton May 10, 2009
    On the memory card I have the right corner looks like it's been cut off, but it isn't. It is just the way it is made.
    Dee
  • JEM May 11, 2010
    Is there a little tab on one side?
    Genius:
  • 1,234 Answers
Hi Mr.
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    2 Suggested Answers
    shockwave727
    • 262 Answers
    SOURCE: Kodak EasyShare DX4530 Digital Camera Digital
    If your using more than 2GB of SD card or if yous using the SDHC card it will not format the Memory card.
    Try to used the recommended Memory card 2GB or 1GB SD card It will reformat your card. Too Much or too High SD card is not compatible on DX camera series
    Posted on Nov 08, 2009
    Memory card will not format in Kodak Z760
    Hi There
  • Jul 22, 2010 | Kodak EasyShare Z760 Digital Camera
    After inserting the new SanDisk, SDHC Card, 8GB the camera prompts "Memory card requires formatting", press continue; warms that formatting will delete everything on memory card; pres continue;...
    First thing; check owner's manual and USA distributor, make absolutely sure that this camera is able to read/write to a 8GB card!
    If so, put that card into your computer, directly into appropriate slot or through a "reader" and the USB port. If computer runs Windows, access My Computer, click on external memory device, and RIGHT CLICK. You will get a box which offers to format the card. You can rename the card at the same time. The computer's format routine is stronger that the one in the camera. If problem still happens, consult distributor. May be fixable with a cable from camera to USB port, you download new software from distributor. Follow their instructions EXACTLY.
    May 14, 2010 | Kodak EasyShare Z650 Digital Camera
    Placed a new sd-hc card in an Easyshare Z650, camera responds "Memory card requires formating" hit continue twice and formatting will not take place. what are my options?
    go to the menu and push (format memory card) then a a warning will come up that says (Warning Formating card will erase all that is on the care) push OK and it should format in might take some time !!Good Luck!!:)
    Apr 02, 2010 | Kodak EasyShare Z650 Digital Camera
    Kodak EasyShare DX4530 Digital Camera Digital Camera Cannot format memory card After I inserted new card, it says that memory card required formatting....I hit Continue...it warn me that formatting will...
    Nov 08, 2009 | Kodak EasyShare DX4530 Digital Camera
    Memory Card
    Hi...
    The way to format is just follow this, you just plug you camera to the computer then turn it on, after that, the camera will detected, you open my computer, you can see the removable disk, just right click then format then check quick, then ok
    Good luck !!!
    Regards
    PCmania
    Jul 06, 2009 | Kodak EasyShare C875 Digital Camera
    Kodak DX4330 memory card formatting problem
    if you have a computer with a card reader, use it to format the card...it's much more powerful and faster than the camera's internal processor.
    Jun 20, 2009 | Kodak EasyShare DX4330 Digital Camera
    My Kodak EasyShare C315 needs formatting.
    For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
    Tami
    Dec 27, 2008 | Holga Flash, 120 Medium Format Camera...
    LEXAR 4GB SD MEMORY CARD FORMAT??
    Preformat : By Fix-shad0w
    #1
    #2
    #3
    #4
    #5
    #6
    With A USB , CELLPHONE , Camera The SameThing
    Nov 29, 2008 | Kodak EasyShare CX7300 Digital Camera
    Memory card
  • Jul 03, 2008 | Konica Minolta DiMAGE Xg Digital Camera
    Kodak EasyShare DX4530 Digital Camera Logo
    476 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
