Canon PIXMA iP4600 Color InkJet Photo Printer Logo
Anonymous Posted on Oct 05, 2012
I want to print 50x50cm id pics using Easy-PhotoPrint EX
  • 2 more comments
  • Anonymous Oct 05, 2012
    I should say I am using windows xp and I have in the past found a post that allows you to alter some parameters in the registery that was to print right up to the centre hole on cd's I am wondering if the same can be done for my current problem
  • Anonymous Oct 08, 2012
    I have the latest software I can print 5.6x5.6cm pics but I want 50 x50 for the new Indian visa
  • jurko175 Oct 09, 2012
    custom paper size
  • Anonymous Oct 09, 2012
    I should say I want to print 5x5cm pics not 50x50
jurko175
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 61 Answers
  • Posted on Oct 07, 2012
jurko175
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
61
Questions
Helped
11380
Points
93
Reinstall the software
5 Related Answers
Karatela
Mohammed Talha Deliwala
  • 38 Answers
  • Posted on Dec 07, 2007
SOURCE: Pixma MP530 Printer Driver
You might have installed a wrong drivers here is link for drivers.
Please select an appropriate driver from the list that opens through this link.
Click here
ShineMicheal
Folusho Adeyanju
  • 132 Answers
  • Posted on Jul 17, 2008
SOURCE: I have just got a
Mac OS X v10.5 Compatibility For Mac OS X v10.5 compatibility, see below:
<Supported models>
BJC-2100, BJC-8200, BJC-85, DS700, DS810, i250, i320, i350, i450, i455, i470D, i475D, i550, i560, i70, i80, i850, i860, i900D, i9100, i950, i960, i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP2600, iP3000, iP3300, iP3500, iP4000, iP4000R, iP4200, iP4300, iP4500, iP5000, iP5200, iP5200R, iP6000D, iP6210D, iP6220D, iP6310D, iP6600D, iP6700D, iP8500, iP90, iP90v, mini260, mini320, Pro9000, Pro9500, S200, S300, S330, S400, S450, S500, S520, S530D, S600, S630, S750, S800, S820, S820D, S830D, S900, S9000
<Supported software>
- Printer driver
- Memory Card Utility
- Network Tool
- Setup Utility
- Easy-PhotoPrint
- Easy-PhotoPrint Pro
- Color Management Tool Pro
- Easy-PhotoPrint EX
<Usage>
To use with Mac OS X v10.5, download the latest version of the software from the Canon Web site.
For Easy-PhotoPrint and Easy-PhotoPrint Pro, use the counter-measured version available for download.
The following models, the printer driver is included in the OS.
BJC-2100, BJC-8200, BJC-85, DS700, DS810, i250, i320, i350, i450, i455, i470D, i475D, i550, i560, i70, i80, i850, i860, i900D, i9100, i950, i960, i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP3000, iP3300, iP4000, iP4000R, iP4200, iP4300, iP5000, iP5200, iP5200R, iP6000D, iP6210D, iP6220D, iP6310D, iP6600D, iP6700D, iP8500, iP90, iP90v, mini260, Pro9000, Pro9500, S200, S300, S330, S400, S450, S500, S520, S530D, S600, S630, S750, S800, S820, S820D, S830D, S900, S9000
Anonymous
  • 137 Answers
  • Posted on Aug 20, 2008
SOURCE: How do I get Vista
You can download Vista drivers and updates for Easy PhotoPrint from Canon's website here.
Regards,
Bob Headrick, MS MVP Printing/Imaging
michael_grey
Michael Grey
  • 365 Answers
  • Posted on Jun 20, 2009
SOURCE: Cannot install Easy-PhotoPrint EX for Windows Ver 3.2
I think Canon is abandoning EZ photo Print and is now offering EZ Photo Print EX.
Basically same program but more options.You can try that.
If it not available from your model try to get it from a newer model.
I think you are talking about a MP450 .
leethedeuce
Lee A.
  • 4472 Answers
  • Posted on Nov 18, 2010
SOURCE: Won't print Easy-PhotoPrint photos: Error
In the program try to go to file print, or the likes. What you need is the printer dialog box to open and make sure that this printer is selected in the pull box. Also depending on your operating system go to Start>control panel>printers(or printers and faxes). Make sure that the printer is set to default. Should have a check mark in a circle. If you can right click it and select set as default then that will make it the default printer. That should help you getting it to print. Otherwise I would delete the printer after downloading the latest drivers and reinstalling the printer. You can get the drivers/software from the link below just click it make sure on the page that opens that drivers & software is selected and then choose your operating system:
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx870#DriversAndSoftware
Only try reinstalling the drivers after you have tried my first suggestions.
Thank you,
Lee
Do you need a computor for a pixma 360
If you are required to use the "Setup Software" e.g. MX360 Printer Driver, Easy-PhotoPrint EX, Easy-WebPrint EX, MP Navigator EX, Solution Menu, you will need a PC for your PIXMA MX360-Office All-in-One Inkjet Printers.
If you are only using the Copier, you don't need the PC.
Hope it helps.
I have a lasser printer CANON LBP-5200 can I to print on photografic paper?, how many gr.?
Are you saying photographic paper or do you mean photoprint paper?
Yes, laser printer print just fine on photoprint paper. I use 20 lb or 22 lb bond. 18lb is a little light and is not usually photoprint.
If you mean overhead transparency, you have to try it. On some units the overhead transparency will melt a bit and wrinkle. You may need to try different makes of transparency. Make sure it says OK for laser printers!
1helpful
2answers
Settings for printing a borderless 8x10 on a canon i9900
Downloaded following program for Vista and was able to print borderless pictures on Canoni9900
Easy-PhotoPrint EX Ver.2.0.3 (Windows Vista/Vista64/XP/2000)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9870#DownloadDetailAct
What canon printers/scanner/copiers are compatible with imac 10.5.5. MP830 is certainly not!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=12804#DownloadDetailAct
File Name and Description
MP780 Scanner Driver Ver. 12.13.0 (Mac OS X)
mp780osxsd12130ej7.dmg
MP780 Printer Driver Ver. 4.8.3 (Mac OS X)
mp780osxpd483ej7.dmg
PIXMA MP750/780 ScanGearStarter Ver. 1.0 for Mac OS X
MP750780SGS10MX_EN.dmg
Drivers
MP830 Scanner Driver Ver. 12.13.0 (Mac OS X)
mp830osxsd12130ej7.dmg
MP830 Printer Driver Ver. 4.8.3 (Mac OS X)
mp830osxpd483ej7.dmg
Software
Easy-PhotoPrint EX Ver. 2.0.1 (Mac OS X)
eppexosx201ea8-2.dmg
08/27/2008
MP Navigator Ver. 2.2.3 (Mac OS X)
mpnosx223ej7.dmg
Easy-PhotoPrint Ver. 3.7.0 (Mac OS X)
epposx370en.dmg
Firmware
File Name and Description Version File Size Date Posted
MP830 Firmware Upgrade Utility Ver. 1.13 (Mac OS X)
fump830osx113en.dmg
Guides and Manuals
On-screen Manual for Macintosh
mp830osmosx100us.dmg
User's Guide
mp830_ug_us_v4.pdf
Easy Setup Instructions
mp830_esi_us_v1.pdf
3answers
Canon i250 printer will not work with window vista os
The Vista add-on module driver (whatever THAT means!) can be found here. Have you tried downloading this Vista driver already?
Hope this helps :)
Scott
How do I get Vista Print Driver for my IP 4000? I can't get Easy PhotoPrint to work
Regards,
2answers
I have just got a Canon Pixma iP4500 but as I use a Mac with leopard OS X 10.5.4 I have had great difficulty with the Easy-PhotoPrint EX that I had to download. When I want to select a photo to print only...
<Supported models>
- Printer driver
- Network Tool
- Setup Utility
- Easy-PhotoPrint
<Usage>
I don't know how to load the 4" x 6" photo paper plus glossy to print a photo, using the Canon ip4000
put the paper on the right corner of the printer. Canon Easy photoprint software will automatically print from the right corner
Click here
old marine
old marine
ZJ Limited
ZJ Limited
