SOURCE: 1994 dodge dakota truck won't start
[email protected] fuel pump is located in the gas tank pop the hood to right of carb or left side look for a black cap that looks like a tire cap it will be on a metal pipe fuel pipe take it of have somebody try to start truck then push the little valve if gas comes out the pump is working if not fuel pump coil i think is mounted left side of motor as you look at it pull coil plug then take some rubber coated needle nose pliers hold near the coil look for blue ark remember this do not hold coil wire with bare hands or bare pliers it will shock you real good my buddy had just a bad coil wire so he got a whole wire set frm autozone they also have a web site autozone,com that will have trouble shooting for your truck let me no what happens
SOURCE: is ther a fuel pump fuse for 2110 dodge 1500 5.9 4 WD
it sound like your fuel pump is bad. but frist see if you have power to your fuel pump. ckeck your fuese inside and out ok
SOURCE: 93 dodge stealth sohc ran fine one day then wouldnt start
first you must determine if it has fire, and fuel pressure if so then injector pulse. Any OBD codes???? you really need a scanner to go any further without guessing.
SOURCE: 92 dodge dakota 5.2
Find out if the truck has a fuel shut off valve that was initialy jarred from the accident. Also check to see that the fuel pump relay is secured.
SOURCE: My 1991 dodge dakota was running fine, then it
There is a conn. by the washer fluid bottle that corrodes apart, u will have to open up the harness to check that. It is a soldered joint. this is a very common problem so check it first.
replaced crank sensor,that failed,replaced the computer it's workinf good
