Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer won't print
When trying to print on my c3180 HP printer the check paper/cartridge light comes on.
  • 50 Answers
Please refer the below link to fix your issue
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00308379&lc=en&dlc=en&cc=us&rule=8471&product=1146331
If this link is helpful please vote
Posted on Dec 31, 2008
Try to print but: get General Printer error 0x61000f6
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Jun 22, 2010 | HP Photosmart C3180 All-In-One InkJet...
The HP Photosmart c3180 prints a color test sheet every time I turn it on even if only to scan a document. How do I prevent it from doing this?
1. Turn on the HP all-in-one.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to initiate the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
a. Press and hold Cancel.
b. While holding Cancel, press On.
c. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
d. Press Cancel again.
e. Press Copies.
f. Press Paper Type.
g. Press Color Start Copy.
h. The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
4. Once the alignment page is printed, place the page face down on the scanner glass and press Scan. The alignment is complete when the On light stops blinking. 5. Reconnect the USB cable.
Mar 15, 2010 | HP Photosmart C3180 All-In-One InkJet...
Wont print
Be sure that the HP printer is your default printer on your computer. If you encounter same issue, you may try to uninstall and reinstall the printer driver. Use the driver CD of your printer for you to do this step.
Jun 17, 2009 | HP Photosmart C3180 All-In-One InkJet...
All lights keep blinking!tried unplugging and reinstalling.Dead?
If the Resume c00121686.jpg light continues to blink and the print cartridge cradle does not move to the right side of the printer, try these solutions:
  • Remove and reinstall the print cartridges. Verify that the print cartridges are in the print cartridge cradle before pushing them forward into position.
  • Verify that no obstruction prevents the print cartridge cradle from moving freely on the rod.
  • Verify that the vinyl tape has been removed from each of the print cartridges.
If the problem persists, contact HP Customer Care.
Jan 14, 2009 | HP Photosmart C3180 All-In-One InkJet...
When try to print the check paper/ink cartridge light blinks and printer wont print.
If both the Check paper, and the Check Cartridge Lights are blinking, this indicates a Carriage Jam. Follow the instructions here to clear this error.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&rule=8471&product=1146331&docname=c01447224
Dec 29, 2008 | HP Photosmart C3180 All-In-One InkJet...
Doesn't copy
Is it working perfectly while printing? Have you try to install a new cartridge?
Try to turn off and reinstall the cartridge again. Also shutdown the PC. Then power on PC & then Printer.
Sep 28, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP c3180 inkjet printer problem
apply two or three drops of 3 in 1 oil to top of the big silver rod (inside printer cover)on which the ink cartridges ride.
UNPLUG RESTART AND Print
Dec 25, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP C3180 all in one printer won't realign
We've encountered several problem like this. Hope this gives an idea; I understand the cartridge will not moved back to park tray or flash ink tray back and forth because the return pick-up guide were not properly placed into each original position. It will block the ink tray moving back and forth. You can roll back the roller into the original place by removing the back cover if it has, then turn the pick-up roller slowly allowing the roller to turn and backed to its original position. Removed also remains of jammed paper pieces.
Best regards,
Rosener Guyano
Nov 29, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
109 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
