Question about Pro RX65 Radar Detector
Need Help with my radar detector
I recently purchased a Beltronics RX 65, and the voice doesn't work. It seems as if it is always in the mute mode, and I have reset factory settings, turned off auto-mute, and still nothing seems to fix it.. Can anyone give me any advice?
  • 134 Answers
Bel/Escort now use a special "high temp" speaker which resolves issues of blown speakers. They can replace the blown speaker inside your RD.
Posted on Apr 20, 2009
How do you replace the speaker?????
Posted on Jun 09, 2008
I tried mine with the ear jack and it worked. I believe you are correct about the speaker
Posted on May 23, 2008
Your speaker is bad more than likely,the heat and cold affect the little speaker and eventually fry it.you need to replace the little speaker.
Posted on Aug 06, 2007
Why are there no audio alerts on my Beltronics Express 795 radar detector? The unit powers up and all alert lights work.. I've checked to ensure the "mute" button is off. I bought the unit new years
I know this sounds silly but check and see if you set it to mute. Most detectors have this option either in the set up sequence or by pushing the volume button down.
but see if you accidentally set it to mute. Most detectors allow a mute setting and only light flash. This can b
Nov 10, 2014 | Express 795 Radar Detector
What does it mean when detector powers on and service required
When powering up, the detector goes through a short diagnostics test to make sure everything is working as expected. If there is a problem detected during this time, a message like the one you have displayed will appear. You should contact Beltronics Customer Support to arrange service with one of the methods listed at the bottom of this post.
A link to the manual for your radar detector is provided below:
http://www.beltronics.com/manuals/rx65manual.pdf
Beltronics Customer Support:
Toll Free
800-341-2288
8am-6pm M-F
Email
belradarsupport@beltronics.com
Beltronics USA
5442 West Chester Road
West Chester, Ohio 45069-2950
Oct 06, 2009 | Pro RX65 Radar Detector
No sound on my vector 940
Beltronics is now using a special "high temperature" speaker which resolves issues with speakers blowing due to high ambient temperatures. Contact Beltronics and schedule service for your V940. Not only will Bel replace the speaker with the newer model, but they will also test and calibrate your V940 and install whatever the current firmware is for your V940.
Jun 22, 2009 | Vector 995 Radar Detector
When i plug in my rx 65 it says service required
it's stolen, or doesn't recognize the POWER supply.
Jun 14, 2009 | Pro RX65 Radar Detector
Bel STi Short or Loose Connection
This most likely is due to a blown internal speaker which has shorted across its voice coil rather than becoming an open circuit. Bel/Escort now uses special "high temp" speakers which resolve any failing speaker issues due to higher temperatures. I assume that your STi is out of warranty. Yet, it will be worth it ($80) to have the speaker replaced and to have your STi flashed with the latest firmware which also gives the STi a true audio ramp-up rather than just the original slow or fast audio beeps to indicate the strength of the detected radar. The new firmware also includes slight performance enhancements, and includes better filtering for Autoscan mode. This latter enhanced Autoscan filtering makes the STi noticeably quieter while driving around town.
Apr 03, 2009 | STI Driver Radar Detector
Service needed
The internal self-calibration procedure has repeatedly failed, causing your RX65 to display the Service Required message. You need to send it to Bel for repair.
Dec 13, 2008 | Pro RX65 Radar Detector
BELTRONICS 940
This is a somewhat common problem that occurs when a strong voltage spike while starting your car damages the radar detector. Bel can fix your RD. Once you get it back, always start your car first before powering on your radar detector. Likewise, power off your radar detector before turning off your car's ignition.
Nov 09, 2008 | Vector 940 Radar Detector
Beltronics rx65
Had to send it off to Beltronics.A common problem they only seem to be able to repair.$150.Yeah,I said the same thing.1-800-341-2288can provide U w/ all that's needed.Thanks
Sep 25, 2008 | Pro RX65 Radar Detector
Radar belronic xr 65
did you check thet fuse in the unit's power cord? Does the lighter socket work in your vehicle? Does the detector work in another vehicle?
Jun 18, 2008 | Pro RX65 Radar Detector
Bel RX65 Radar Detector
Call Beltronics tell them you have an RX65 out of warranty. They charge about $65. When I did mine I sent them only the detector and they also set me a new cord & suction cups.
Aug 14, 2007 | Traveller II Radar Detector
Pro RX65 Radar Detector Logo
438 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Steve
Jerry Greenberg
Jerry Greenberg
David Payne
David Payne
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
