Question about Whirlpool GEQ9800P Electric Dryer
Whirlpool GEQ 9800
I'm replacing the door switch. I'm assuming I have to remove the top for access. Can you tell me how to remove?
    New Friend:
  • 88 Answers
If you have the filter on the top take the 2 philips head screws out by the filter. Use a flat head to pop the clips in the front there are 2 one on each side about 2inches from each corner. If you have the other model take off the 2 philip screws on the back of the console flip the console up and remove the 3 1/4in screws from the top. don't forget to unplug good luck.
Posted on Jan 08, 2009
  • 115 Answers
To remove the top if it has the filter in the top take the 2 phillip screws out then put your hand on the back and push to the front while lifting on the front you have to do this on each side
Posted on Dec 30, 2008
How to access dryer door switch on whirlpool dryer model len2000jq1?
Rob, Second link, go to how to replace dryer belt video, it will show how to remove top of dryer and get access to door switch.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My LEN2000JQ1 Model Overview from PartSelect ca
http://www.appliancepartspros.com/parts-for-whirlpool-len2000jq1.html
May 13, 2016 | Whirlpool Dryers
How to replace dryer door switch on whirlpool model len2000jq1
Rob, I believe I may have answered this in an earlier post, here it is again, 1st and 3rd link, scroll down to how to replace dryer belt videos, it will show how to remove top of dryer and get access to door switch.
Whirlpool Dryer Model LEN2000JQ1 Switch Door Switch
How do I get to the door switch on a Whirlpool LDR3822HQ dryer
To access that door switch what ya need to do is firstly remove the top by removing the screws from the rear of it and slide the top toward the back then lift it off.then you see it the back side of the front panel at the top screws that hold the front panel to the remainder of the cabinet remove those screws and the front panel will come off where as ya can access the door switch.
GENE
Sep 30, 2011 | Whirlpool LDR3822HQ Electric Portable...
My GGQ 9800 gas dryer won't start. It was working
Things to check first on a no start dryer.
Check for power at outlet.
Inspect power cord.
When you try to turn it on do you hear anything?
Check the door switch(does it click when pressed in?)
The next item to check and most likely replace on a completely dead dryer with power and a good door switch would be the thermal fuse located inside the cabinet.
Please let me know if I can help with anything else
Apr 08, 2010 | Whirlpool GGQ8831L Gas Dryer
Drum does not turn
HI. This may be a possible belt issue. the belt may have slipped off, or failed. To access, simply, remove the access panel on the rear of the unit. Once removed, you will be able to inspect the belt location.Replace the belt, if needed.
Additionally, if the belt is ok, i would recommend to move on to the door switch. Most units are designed to not spin, if the door switch circuit has failed. Use the procedure below to test this switch.
The door switch may be accessible without removing the front panel or cabinet. The switch is located in the front panel of the dryer, around the perimeter of the door opening. Inspect the switch to determine if it can be popped out or accessed by removing a fastening screw. If it cannot be accessed from the front, it will be necessary to open the dryer cabinet. When reaching into the dryer be careful of sharp edges on the cabinet and interior supports.
Access varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
Locate the door switch, it typically has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the switch, the reading should change to zero.
If the switch does not test as described, it should be replaced.
Now, if the door switch is ok, and operational, the motor will be the culprit.
Dec 06, 2009 | Whirlpool LEB6300 Electric Dryer
DRYER WILL NOT WORK
First check the electrical panel to your house. If it's a fuse panel check the fuses. If it's a breaker panel, reset it by flicking it off, then back on (do this even if it looks like it's already on).
If the dryer still doesn't work...
1) Check the door switch by pressing it in and listening for a clicking sound as you do so. If the door switch actuator spring is broken or if there is no click, replace the door switch assembly. This is done by removing the 2 screws under the lint trap screen and lifting the cabinet top. From there you can access the door switch. REMEMBER TO UNPLUG THE DRYER! You can also use a jumper wire on the door switch to verify it's function (unplug the door switch and connect a jumper wire to the 2 wires going to the console.
2) Check for a broken belt by lifting the cabinet top and visually inspecting the belt or by manually turning the drum from the inside (you should feel resistance or hear the motor turning).
3) Unplug the dryer and remove the back panel. On the heater housing remove the wires from the thermal cut-off and high limit thermostat and check the resistance with an ohm meter. If either of them are open (no reading) replace both (they come as a kit).
3) If everything checks out so far it may be the timer.
Feb 17, 2009 | Whirlpool LER7646E Dryer
The dryer will not turn on.
Well, thats the door switch. Probably the plastic locking flanges that holds it in place are broken off allowing it to fall back in the cabinet. The flanges and switch are one in the same part itself and not very expensive, but you have to remove the top deck of the cabinet to access the switch/wiring harness and render replacement efforts. You can purchase the part thru Sears/Kenmore by giving them your Whirlpool model number. Once you have the part, be sure to unplug your machine first before attempting this! Safety first!
Dec 18, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer LEB6300 door
you have to lift the top cover. then from there you can access the door switch of the dryer.
look closely between the front wall and the top cover. pry the top cover slowly and push the plastic lock that is holding the top cover.
then you can see the switch now and replace.
tnx 4 using fixya,
drcool
Sep 08, 2008 | Whirlpool LEB6300 Electric Dryer
I am trying to figure out how the cabinet to my dryer comes apart so I will be able to replace the heating element.
If your dryer has the lint screen on top of the cabinet, the heating circuits are located in the rear of the dryer. They can be accessed by removing the rear panel.
If your dryer has the lint screen in the door, the heating circuits are located under the dryer drum. They can be accessed by removing the lower panel under the dryer door. The panel comes off by inserting a putty knife in the seam, about 2 inches in on each side and depressing the release tabs. If this is a Kenmore Elite or Whirlpool Duet model, the lower panel comes off by removing the screws under the bottom edge of the lower panel.
If there is no removable panel, the entire front casing needs to come off. This is accomplished by lifting the dryer top to gain access to the screws that hold the front panel place. Use care not damage the door switch connector(s) in the process.
Lifting the top panel can be accomplished in the following ways (depending on model):
1. Grab the sides of the top panel and pull towards you while lifting up.
2. Lift the operator console first and then remove the three screws holding the top panel in place. Once the screws are removed the panel slides forward, then off.
I hope this is helpful to you. If you experience problems, please post back with your model number, so I can narow down which dryer configuration you have. Good Luck.
Jun 06, 2008 | Whirlpool Dryers
Duet Dryer
Hi kroeter,
It is possible to reach the door switch by removing the bottom front plate on the dryer. You will see it above the right side. Before you reach into this section please make sure to unplug your dryer. If you need full access to the switch you will need to remove the top then the console then remove the entire front. You will need some torx screwdrivers. Start by removing the torx screws on the back top, then the top will slide back and you can remove it. Underneath that you will see the top of the console on the front, remove the screws in the console and lift it to remove. then you will be to the top of the door section again you will see torx screws, remove and lift the door section and you will be to the door switch. Good luck and I hope this will FixYa.
Mike Anderson
Jun 02, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool GEQ9800P Electric Dryer Logo
203 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
