Question about SanDisk Sansa e250 MP3 Player
Wont go to main menu
The mp3 only starts up then continue doing the same thing. it doesnt go to the main menu where i have options to do anything what should i do??
  • Alex488 Dec 30, 2008
    My player does the same thing, it turns on, the blue circle lights up and it says sandisk then the screen goes white and it says sandisk again.
  • 4 Answers
Try taking out the battery for awhile or letting the battery completely die
Posted on Dec 30, 2008
2002 grand cherokee, overland 4,7L engine doesnt
Hi Joko,
What you are describing is a failure of a main circuit. The first thing you should check is yo make sure that your battery is in good condition and that the cables are clean and tight. Let me know if yu find anything wrong there. Then there may be another main circuit problem. Check all of the fuses in your fuse block in the engine compartment. If any of these fuses are blown, it will usually cause several things to not work. If you find any fuses blown, DON'T REPLACE IT YET. Let me know WHICH fuse is blown and I can help you find out why it blew so you can get the problem fixed.
Get back to me on this and we will continue.
-Dave (dttech)
Nov 17, 2011 | 2002 Jeep Grand Cherokee
I can't put an ebook in the ebook folder
I work for COBY tech support. Our number is 800-727-3592.
In order to see all of the files on that device, you must put the device into a different USB mode called MSC. Disconnect the device and then please follow these steps:
  1. Choose "setup" option in the main menu.
  2. Choose "system" option in the setup menu.
  3. Choose USB mode in the system menu.
  4. Change USB mode to "MSC"
  5. Go back to the main menu, then reconnect device.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 11, 2009 | Coby MP-705 Digital Media Player
I tunes screen appears when turned on
you can re set it., hold down the menu key and the arrow key at the bottom... im pretty sure you wont lose all your songs.. if this doesnt work your only other option is taking it to apple
Mar 24, 2009 | Apple iPod touch
Sansa 260 Won't Let Me Navigate Back to Main Menu
The power button is also the Menu button - click and release once while the player is on, and see if it gets you back to the main menu. Or press the left arrow key and see if it will get you back to hte previous menu.
-Tha Mp3 Doctor
Feb 21, 2009 | SanDisk Sansa e260 MP3 Player
Computer(s) wont recognize sansa e260
i have the same SANSA e260.....and the same problem....its easy just turn on your sansa then push the menu botton, slide the wheel in the center and at the end of the options say USB enter there and change usb mode from MTP to MSC mode.....and ready
Jan 02, 2009 | SanDisk Sansa e260 MP3 Player
Ipod wont switch on
what you should try doing is holding the centre and menu button at the same time for 6 seconds it should work. if it doesnt im sorry i dont have a solution otherwise. lol at the moment my ipod is doing the same thing but try the menu and centre button it should work
Jul 20, 2008 | Apple iPod nano MP3 Player
Rca rp5011a
Regarding RCA RP5011A
Turn on = Play + Menu (at the same time)
Turn off = Stop (will revert to just clock)
Selecting folders or changing options = Turn on then press menu to move through options and use the forward and backward buttons to change within options
Deleting a file within a folder = Select the folder through menu options (A or B) then exit menu (cycle through all options or press stop once while in menu) then press the forward key to cycle through files within folders (1 or 2) then press delete once to display "Del" next to file then press delete a second time to delete file.
Take batteries out to quickly reset recorder (will not lose saved files)
Jun 06, 2008 | RCA RP5011 Digital Voice Recorder
Not connecting to pc
You may want to get a new USB cabel.
I have had the same problem before.
Apr 19, 2008 | Samsung YP-Z5 MP3 Player
Grrr
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 23, 2008 | Philips SA5125/37 MP3 Player
No Music Menu on Ipod 160GB
Okay,on my nano, i sorted this by going to...
Settings,
Main Menu.
and clicking on music so a tick appears next to it.
this means it appears in the main menu.
Hope I Helped.
Sophie x
Feb 03, 2008 | Apple iPod MA446LL/A MP3 Player
SanDisk Sansa e250 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
