Question about HP Photosmart C3180 All-In-One InkJet Printer
When try to print the check paper/ink cartridge light blinks and printer wont print.
  • 63 Answers
If both the Check paper, and the Check Cartridge Lights are blinking, this indicates a Carriage Jam. Follow the instructions here to clear this error.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&rule=8471&product=1146331&docname=c01447224
Posted on Dec 30, 2008
I put in new ink cartridges and now there is an E and 2 red blinking lights
Which lights are blinking red? What is the rate of the flashes? I'll assume that one of the blinking lights is the power light (just means error).
If the either of the ink cartridge lights is blinking rapidly, the cartridge may not be seated correctly. Try reseating the cartridges and then press OK to clear the error. If it is a less rapid flash it could be that the print head isn't reading the cartridge ink level correctly. Please note: refilled or non-Epson cartridges may not be read correctly due to information stored in a chip on the cartridge or in the printer.
In this case the problem may be in the print head and Epson doesn't recommend cleaning this yourself. You can replace it. (On other inkjets, pop out the cartridges, remove the print head and wipe with soft, lint-free cloths or q-tips dampened with bottled or distilled water (wring out excess water). On each section, you wipe away from the nozzles. Then wipe off the inside of the print head carriage (contacts) as well. Dry everything with a dry cloth and reassemble the printer.)
If the Check paper light is blinking check for a paper jam or the printer looking for a different paper size.
I hope this helps.
Oct 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
The ink light is blinking orange and the printer will not take in paper and print but the ink cartridges are about half full.
Reset the ink cartridges by taking them out and reinserting them! Make sure the ink in the cartridges is liquid. that should solve the ink light problem.
If the printer does not take the paper, try realigning the paper in the paper loader so the printer sensors knows its there. Hope this helps:)
Jul 24, 2010 | HP DeskJet 710c InkJet Printer
I can't print.
“All lights blinking and printer not responding” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i. Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii. The Cartridge electronic panel is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Dec 06, 2009 | HP Photosmart C3150 Printer
Printer wont print, computer communication error that wont send information to the printer, but the scanner will scan to the computer. Power light on the printer blinks 2 times, pause, blinks once, pause,...
“All lights blinking” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still. If it an All-in-One it still scans though. This could be as a result of eithe of these of scenarios.
i. Ink cartridge has developed incompatibility. Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. Solution is try to clean with a piece of folded tissue paper soaked in a bit of methylated spirit. Also clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue.
Dec 06, 2009 | Lexmark X1150 All-In-One InkJet Printer
Top light blinking, will not print
I believe that the top light is the low printer cartridge signal. Did you replace the cartridge or just take it out and reinstall it? Did you use a new HP cartridge or refilled cartridge?
Try a new ink cartridge from HP and double check that you have the correct cartridge for your printer. If that doesn't solve the problem, contact HP.
Sep 15, 2009 | HP DeskJet 5550 InkJet Printer
Blinking light--won't print
give a try to dis one..
Remove all the cartridges and the paper from the printer...Power off the printer...unplugg the power cable from the back of the printer...while printer is unplugged from the power..press n hold the power button for atleast 60 seconds then release it..open the back door of the printer and look for any paper jam...remove paper from behind (if any) and roll the rollers in upward direction from behind..close the back door and connect the power cable to the printer and power on the printer..Look for the cartridge slots and clean it wid a lynt free cloth and the copper contacts of the cartridges as well...then insert only one cartridge (black or color) and close the cartridge door and check for any blinking lights on the printer...similarily repeat it with the other cartridge..by this u wud get to know if any cartridge is faulty? If u get blinking lights on the printer ...that means there is some problem,,,
Once you see the steady green light on the power..it means the printer is ready..You can also print a test page..."Press n Hold the power button down...while holding the power button down...either press "Down Arrow button" 4 Times OR "Red X button once"...then release the Power button to print the test print..
If it prints ..u r the master !!!
Best of luck
Remember if there is any blinking light,,the printer wont prin..
if the light blinks around the drops..it means there is cartridge issue and you may even replace the cartridges..make sure u remove the pink tape carefully before inserting the cartridges.
ALL THE BEST
Mar 22, 2009 | HP Deskjet 6940 InkJet Printer
Printer wont feed paper and power light keeps blinking.
must have both cartrages in to work. insert another one turn off and restart his should solvre problem
Dec 22, 2008 | Lexmark X73 All-In-One InkJet Printer
Red light ink cartridge keeps on blinking
what does it say next to the blinking light for example check paper, check ink cartridge, etc.?
tom
Dec 20, 2008 | HP PSC 1350 All-In-One Thermal Printer
Replaced ink cartridges and check ink cartridges still blinks
If your software is installed correctly when your printer, connected via USB?, the printer icon in the system tray can be clicked and bring up the printer utility. From there or at the printer control panel you can instruct it to align and or clean the print heads.
Worldvet
May 31, 2008 | HP PSC 1510 All-In-One InkJet Printer
Printer bling ect
Dear friend this light blinging problem is with Print cartridge please check cartridge with Ok printer .
100% u r problem is solved ...
& at ones time Printer get all paper
this is a default printer tray alliment problem .so u take care that your paper bunch is no longer insetred in to printer just under pickup roller.
if problem is solved please Rate me ...
May 23, 2008 | HP DeskJet 3745 Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
492 people viewed this question
Seeker5211
Seeker5211
