Question about Samsung ML 2010 Laser Printer
Samsung ML2510 The ! symbol is light is on and the printer won't print. I have changed the cartridge, but the printer still won't print. I dont seem to have received a manual with the printer that tells what could be the problem when this light is on.
  • Anonymous Nov 07, 2008
    cxzczczxczxczxczxczxczxczxczxczxczxczxczxczxczx
  • seanog57 Dec 03, 2008
    My printer has a green light but still will not print.
    We had been using some ink jet paper but other than that no complications or other issues.
    What can I do to get it printing again?
The manual is under the program files in your C: drive.
Posted on Aug 28, 2007
The red light will come on for mant reasons. One is the access covers. Make sure the top and front cover are closed completely and the litte plastic tabs activating the sensors.
Posted on Aug 20, 2007
Do you have paper in the tray? No paper loaded is one reason for the red light.
Posted on Aug 11, 2007
SOURCE:
Accidentaly deleted the driver for my Samsung ML2510 printer
hi if you have lost your disc.
dont worry you should be able to look up your driver via the internet and download there. hope that is of help
Jan 17, 2013 | Samsung Black Laser Toner for ML2010...
I purchased the samsung ML2510 and it didn't come with a manual. I have it hooked up but both lights are flashing and it is not printing. What could the problem be.
You can download the manual from the manufacturer's web site at
http://downloadcenter.samsung.com/content/UM/200809/20080926100848859_Guide_English.pdf
Nov 10, 2010 | Samsung ML-2510 Laser Printer
I lost my manuel and can't seem to remove old cartridge samsung ml2510
hello Try this : static.tigerdirect.com/pdf/Samsung-ML2510-Manual.pdf
Sep 22, 2009 | Office Equipment & Supplies
Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Jul 29, 2009 | Samsung ML-2510 Laser Printer
Light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
May 21, 2009 | Samsung ML-2510 Laser Printer
Samsung ML2510 laser printer not working
unplug from the wall and try it again after an hour
Jan 10, 2008 | Samsung ML-2510 Laser Printer
Samsung ML 2010 Laser Printer Logo
262 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
