Question about Philips Magnavox 51MP392H Rear Projection Television
Red green wont converge
I have a magnavox 52" projection tv. We were out of town for a week. Cam home and it was messed up. The red green will not converge right to left but WILL converge up and down. Any ideas?
  • rogerwhastin Dec 30, 2008
    should this be done by a pro or can I do it myself? I am an electrician but my world is a lot different than electronics! Do these require soldering?
    Thanks for your help.
    Sergeant:
  • 233 Answers
Your screen has gone crazy on you because your convergence IC's have gone bad.   These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.   Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.   If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!   If this STILL doesnt make it look right, you will need to find out how to get into service mode and do a coarse convergence adjustment. This information can be found in the Service manual for your set. If you dont have one you can download it at servicemanuals.net   Hope that helps!
Posted on Dec 30, 2008
  • Josh Crager
    Josh Crager Dec 30, 2008
    yes, you should be able to do this yourself If you have an aptitude towards electronics, and some soldering experience...
RCA D52W23: Only partial convergence menu. I can only access Autoconvergence, Red and Blue convergence options (not Level 1, 2, 3, etc.) in the service menu. The picture is only slightly off (i.e. green...
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 31, 2011 | RCA D52W23 52" HDTV CRT TV
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
Blue, red and green are separated and i cannot find convergence from main menu
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 22, 2010 | RCA P52939 52" Rear Projection Television
WD-52525 52 in. Rear Projection HDTV Television: my mitsubishi projection tv has a distorted pictur...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a 52'' Magnavox Projection screen tv and the colors are messed up. The best way to describe it is that it looks like your looking at a 3D movie without the glasses. Can you tell me what's going on?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Philips Magnavox 51MP392H Rear Projection...
Jvc 52 rear orijection top has doulbe image in
Ur convergence is dead.Must know how to solders?Must replaced 2 convergence ICS and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 14, 2010 | JVC HD-52Z575 52" Rear Projection...
Green auto convergence
The master convergence settings have to be close for the Autoconvergence to work. If they are not you need a technician to go into the service menu and adjust them.This is a long job and you can't do it yourself.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Maganvox TV with red-shadow to picture
Hi Emily,
Your TV has bad convergence amplifiers. They are large integrated circuits that are mounted on large metal heat sinks. They have a part number on them, but might be covered up by a bracket. The part number should start with STK. They are replaced as pairs. You will have to find someone with the skills necessary to replace them.
Best Regards,
MyTvGuy
Feb 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
134 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
