Question about HP Pavilion Slimline S7410N Notebook
Computer shuts down and wont turn on - HP Pavilion Slimline S7410N Notebook
  • coolguyci Apr 21, 2009
    I bought this computer a year back and notice that when i was in the middle of something it would shut off without notice its a HP slimline desktop I have no other problems with it other then that. I don't believe i have a warranty anymore and even if i do i'm not sure it would be worth the time to send it in. Can anyone tell me if they have experience this type of problem and how did they fix it. I really mean it gives me no warning no powering down or anything.
  • Vern Haynes
    Vern Haynes May 11, 2010
    How long does it take to turn off?
    And will it restart after you leave it off for an hour or so?
Msi u210 notebook won't shut down still stuck in update modee
hold down power button for 10 seconds should turn off
sometimes it will mess your computer up turning it off while doing updates
Jul 09, 2015 | MSI U210-008US Notebook
Wont turn off
what model is the computer..what operating system are you using..how are you turning the computer off.? and is there any updates installing ..if the last is true then you have to let them finish then the computer will shut down on its own when there done
May 30, 2013 | Toshiba Satellite C655-S5125
Computer wont start and when it does it shuts itself down
Sound like a power overload system is kicking in, which means either a bad power supply or shorted circuit else where. Disconnect the DVD, CD, and any other devices to narrow it down. Try another known good power supply. If all this fails, it's going to be a problem with the motherboard, by elimination. There can be an intermittent capacitor or electronic heat sensitive part that's shutting down the computer. There are diagrams and videos on the net that can guide you through possible problems, in case you want to fix it yourself. Google "Intermittent Computer Startup" and you will find some good suggestions. One site is this one:
http://www.ehow.com/how_5880187_troubleshoot-intermittent-shut-down-computer.html
Good luck.
Apr 15, 2010 | Computers & Internet
At times pc wont turn off with mouse windows shuts down but computer will turn off and on again immed
Try draining the power of the computer first. completely shut it down by pressing poweer button for like 5-7 sec. then unplug power supply from the outlet. then press and hold power button for another 15-20 sec. After that, plug back in the power cord, and turn computer on normally.
Apr 03, 2010 | Compaq Presario 5000 PC Desktop
My A215 wont stay powered up. It shut down and
Try running the computer on the Battery power and check if the power sustains. If not, then disconnect the power cord and remove the battery and leave it for a few hours then try turning it on.
If the problem exists then the power supply unit is required to be replaced. You may contact service center to get the power supply unit replaced.
Oct 01, 2009 | Toshiba Satellite A215-S7422 Notebook
Lights wont turn off...
wnhook it completeley from the computer. then it wont have any power to turn on
Jul 14, 2009 | Computers & Internet
My laptop won't shut down properly!
Is it possible that you have changed the settings of what buttons do what on your system? E.g. you could have changed the power button to "switch user" instead of "shut down", to check this (in XP) go to "Power Options" (in Control Panel" and then click on the "Advanced tab" at the top, then select "Shut down" from the drop down menu at the bottom of the window.
If this is already set to shut down then maybe you could do a system restore in case another setting has been changed, restore it to before the PC started doing this.
Alternatively try actually choosing "Turn off Computer" from the Log On screen (press Ctrl + L to get to this screen, or choose switch user/log off). If you are using Vista I beleive that there is a shut-down option from the Log In Page there (which again you can access by pressing Ctrl + L on the keyboard.
Hope this helps!
Dec 29, 2008 | Computers & Internet
My Philips Freevents sometimes wont turn on and when it does it shuts down without me shutting it down
If the computer shuts down with no warning then it could be your power supply is faulty, which explains it not turning on sometimes. Just check the back of the PC to make sure it is plugged in properly (TURN OFF ALL POWER TO THE PC BEFORE CHECKING). if this does not help, get it looked at by your local qualified computer technician if you don't know how to replace a power supply. Also, a connection to the motherboard to the Power button may have a fault somewhere, which also means take it in for a look if you don't know what to do. If it does give you warning with 'Windows is shutting down' it can be the following things.
1- Your power button on the PC is sticky and movement causes the computer to think you have pressed it and so it shuts down, which can also explain why it wont turn on all the time. Just use some household grease cutter and spray it on the outside of the button, turn off the power supply to th computer and press it in and out a few times to get it back to working order
2- A Virus is shutting your computer down on you, but this does not fully explain why it won't turn on but this could be an effect of the virus so use a virus checker to see if this is the case
3- Your computer system is getting too hot and usually a computer has setting which shuts it down before permanent damage happens. Check your PC fans to make sure they are running and feel around where your computer sits to see if its warm or hot and replace the fans or put your PC in a cooler environment
Hope This helps
Nov 18, 2008 | Computers & Internet
I cant get my mouse pad to work after turning it off in control panel. Im on windows vista and on a lap top. Curser wont work so cant go back in to turn it on again.
Hold the Alt key and press F4. Press Enter to shut down the computer.
Once it's shut down, press the POWER button on the computer's system box to turn the computer on again and reset it back to normal.
Hope this works.
Jul 20, 2008 | Acer Computers & Internet
My computer shuts down after 3 secs
Try to separate the power cord of your monitor from your system or maybe if your using UPS(uninterrupted power supply) directly plug the UPS to the wall outlet. either you can use pretty voltage regulator to the regulate the AC power.
if not solve the problem try to examine the your system power supply.
Dec 11, 2007 | Computers & Internet
Open Questions:
HP Pavilion Slimline S7410N Notebook Logo
168 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
