Created spark. now car wont start, windows wont go up, radio wont work, etc... basically, all fuses inside cabin are blown?
SOURCE: 1990 toyota pickup wont start/turns over no spark or fuel
there may be a bad contact problem check the wire running into the fuse box and look at the relay for the efi
SOURCE: I can't find where the fuse box for the radio for corolla 2006
The radio fuse is a 15amp and is located in the fuse panel on left side under dash area. There may be a black cover over the panel.
SOURCE: MY 1994 fuse for
Another fuse block is located in the drivers side knee bolster behind a coin box—1994-96 models
On the back of the coin box on some models is a fuse listing
SOURCE: location of fuse box for 98 toyota corolla
Also, for radio, cigarette, and others: behind the "storage only" box left of steering wheel. Pull that door open, up and out.
SOURCE: how to get to underdash fuses of a toyota matrix
The 15 amp dome fuse is in the fuse box under the hood and the 15 amp CIG fuse is in the lower finish panel up under the dash on the drivers side. These are needed for the radio. The above fuses plus the 15 amp Gauge fuse in the box with the dome fuse under the hood are needed for the clock.
If the clock is the only defective module, I have removal instructions and a repair service. Check out www.autoclockrepair.com
