GE top load washer does not agitate or spin.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} My GE top load washer (model WLRR5000G0WW) does not agitate or spin. The washer will go through the entire cycle. I realized that something was wrong when I opened the
machine at the end of the cycle and the clothes had not moved and there was still
soap on the top layer of clothes. The outer tub was tilted to the left. I took the
panel off and found that one of the suspension rods was off of the frame. I put it
back on - hoping that the problem was solved. Unfortunately, that's not the case.
I Checked:
Suspension rods: All 4 are attached now
Door/lid switch: No loose wires. Not sure if that is the problem.
Drive Belt: Still attached. I can turn the wheel (?) and the belt moves the tub. No
oil residue. (I read that oil on the belt was bad?)
So I ran the cycle and watched the washing machine... here is what I saw:
Fill: The washer fills up with water just fine.
Wash: Nothing. No motor, no noise. Then after 5-8 minutes, the motor turns on and
pumps the water out of the tub.
Rinse: The washer fills up with water just fine. Then after it is full of water, the
motor stops. Then nothing. After 5 minutes or so, the motor turns on and pumps the
water out.
Spin: The motor runs with the empty tub, but the tub does not spin.
The cycle ends when the spin cycle is over.
Help! What could the problem be?
Thanks!
Jen
  • jenjenrosebu Dec 30, 2008
    It's about 2 - 3 years old. How long do they typically last?
  • Roger King Dec 13, 2013
    If the washer pump doesnt remove the water from the tub it will not go into the spin cycle. Check the drain pump to see that it is working. Clothes can get stuck in the pump and cause this issue
  • 115 Answers
Sounds like a bad lid switch how old is it?
Posted on Dec 30, 2008
  • Steven Carter Dec 30, 2008
    if it has a computer board on top of the motor then you need to reset it to do that you will need to unplug your machine for about 2 minutes then plug it back in then open and close your lid 5 times this will reset it
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
Dec 19, 2009 | GE WBB4500EWW Top Load Washer
I own a ge hydro washer. It won't spin or agitate
If you hear the motor go through the stages, but nothing is happening in the tub, the motor belt may be broken or off.
Aug 31, 2009 | Washing Machines
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
May 28, 2009 | GE WBSR3140DW Top Load Washer
Will not agitate or spin
Check 1. the water level switch, 2. the timer, 3. the lid switch.
May 15, 2009 | GE WBSR3140DW Top Load Washer
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE top loader not agitating
Your agitator splines are probably stripped out.
Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
Mar 04, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
605 people viewed this question
Top Washing Machines Experts
