Question about Samsung ML-2551N Laser Printer
No display and no connectivity to the computer
When I turn on printer light on the sceen come on but no think of the botton work or any instruction display on the secreen
  • Anonymous Jan 02, 2009
    Following my return from vacation for a week, the screen said "incompatible toner." When I turned it off and back on, the printer now says nothing in the screen area, and is unresponsive.
  • 104 Answers
Replace all electrolytic capacitors in power supply section on mainboard. caused by poor quality lower voltage caps being used in powersupply. Problem will reoccur every 2 to 3 years if 105oC caps are not used. If mainboard is replaced with new mainboard problem will reoccur within same timeframe. Fix old mainboard using higher voltage and higher temp caps and problem will be gone for good.
Posted on Jan 06, 2009
My cannon MX320 printer light are flashing both the on and alarm button - message contact service center, printer error has occurred at the botton of the sceen it shows B200
This error refers to a voltage problem within the print head. Usually the fix is a new print AND the main logic board.
Personally i feel its an end of life error and you should consider replacing the machine as the cost of repair is more than it would be to buy a new printer.
Sorry
Aug 25, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Printer sporadically displays a red light three successive flashes error and will not respond to till / keyboard. What does this mean?
PUT PAPER INSIDE PRINTER POWER OFF THE PRINTER.
THEN PRESS & HOLD THE BUTTON ON TOP OF PRINTER
BY HOLDING THE BUTTON NOW SWITCH THE PRINTER ON & WAIT UNTIL THE SIZE OF PAPER IS SCANNED .
IT WIILL BE DONE.
Feb 08, 2011 | Epson TM88II Thermal Printer
WE HAVE MODEL #EP1031F. THE "READY" BUTTON DOES NOT LIGHT UP, COPIER DOES NOT PRINT. THERE IS ALSO AN ICON LIT UP BY THE COUNTER WINDOW THAT LOOKS LIKE A CROWN. IS THIS INDICATING IT NEEDS...
Have you installed a new toner??? It may take a few minutes for the copier to add enough toner to make a copy. It's been awhile scince I've worked on one... But I think if you turn it off and hold down the Clear/Stop botton when you turn it back on, it will make the copier add toner... It looks like the display i chashing a box in the display. Good Luck
Nov 01, 2010 | Minolta EP1031/1031F CS/PRO Copier
# 3 and H Flashing ... will not do anything else ?
TO RESET THE MACINE PRESS THE ORANGE BOTTON (C),PRESS THE BOTTON UNDER THE AUTO DENSITY LIGHT,RETURN TO THE FIRST ORANGE BOTTON THEN THE AUTO DENSITY BOTTON, YOU HAVE TO BE FAST WHEN PRESSING THE BOTTONS, ALL THE LIGHT ON THE DISPLAY WILL GO OFF THEN PRESS 14 AND PRESS THE GREEN PRINT BOTTON,THE MACHINE WILL RESET AND START TO WORK, BUT IF THE PROBLEM COUNTNUE CHANGE THE FUSER UNIT.
Sep 10, 2010 | Sharp AL-1000 Copier
The sceen wont turn on the little light is flashing but the sceen doesnt turn on the computer is perfectly on but sceen doesnt see that >.>
First make sure that your VGA cable comming from the back of your monitor is still connected to your computer, check both sides on the back of your copmputer and your monitor if they are both in then maybe your cable is bad.
Sep 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Zebra prints one page then light turns red.
TRY HOLDING THE BUTTON DOWN AND LET IT FLASH 5 TIMES. RELEASE. WHEN THE DIMENSIONS ARE AT THE CORRECT NUMBER PRESS THE BUTTON AGAIN.
Aug 19, 2009 | Zebra LP 2844 Thermal Printer
The sceen has been freezed can get any function working
Use system restore by following the instructions that came with it.
May 22, 2009 | Cowon System iAUDIO G3 MP3 Player
Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Display not lighting up
i think whoever squeezed ur phone,squeezed WAY to hard and took the color cartirge out.try gettinbg a new 1.i have NO idea about the volume...
Jul 18, 2008 | Motorola Mobility V31 RAZR GSM Cell Phone,...
Samsung ML-2551N Laser Printer Logo
125 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
