Question about RCA F20TF10 20" TV
Picture Quality Issues
I have an RCA F20TF10 20" television. I've had it for about 5yrs. and the picture quality is not so great. When I use the remote to select "Menu", when the menu appears on the screen, it's almost black and is difficult to read, unless you stand right in front of the television. When I first purchase the t.v., the menu was easy to read. I think it was blue with white letters. Anyway, I was wondering if there's a way to reset the manufacturer default settings of the television? Somewhere along the line, I must have changed something and now I'm having a difficult time adjusting the picture quality of the set. Thanks, Jacki
  • Anonymous Feb 29, 2008
    I have a picture, but no sound. Please advise me how to handle.
  • raivyn Jan 07, 2009
    same as Jackie and too much black. Cannot see dark movies/shows
SOURCE:
  • 119 Answers
SOURCE: FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Posted on Nov 03, 2006
SOURCE: RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Posted on Jan 05, 2008
snakehead
  • 1074 Answers
SOURCE: RCA 27v520t menu is blocked and wont let me into menu
your set problem is internal so my advise is to call up your tech,for posible repair on your partially damage micro chip,
Posted on Jul 12, 2009
joez47
  • 61 Answers
SOURCE: RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Posted on Sep 13, 2009
SOURCE: tv has sound but not picture
i have the same problem, whatever happen to plain ole tv, that's why I'm on this site, looking for answers. I misplaced my manuel.
Posted on Nov 05, 2009
How do i adjust picture quality settings TV
Find your owners manual that came with the television, it should have all this information in it.
May 15, 2014 | RCA 19LB30RQD 19-Inch LCD 720p 60Hz TV
Works fine 30 minutes then no picture
Q502 must be top-shelf , first-quality only = no generic.
Use RCA 237470 or Sony 8-729-035-75 Both are first quality,
but RCA much less expensive..............................T.
Please rate this solution......................
Note:Blow-up caused by bad connects in horizontal driver
circuitry.Therefore,save your good,used flyback!
Nov 13, 2007 | Sony KV-35S65 35" TV
Sharp 40e67un issues with digital picture quality.
try contacting your cable company and see if they have some sort of signal booster available
Mar 18, 2010 | Televison & Video
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Hd quality
it sounds as if your need to tweak your picture settings from the menu you should be able to go to menu then select pre set setting and or tweak diferrant part for your viewing pleasure, it would seem they were off before you upgraded box to hd
Jan 11, 2009 | RCA D52W19 52" Rear Projection Television
Picture quality
i have a similar problem, when watching football the picture is terrible,but when im watchin ordinary tv its great
Dec 28, 2007 | Samsung LN-R409D 40 in. LCD Television
LCD RCA quality issue with V.Smile
No picture or sound on TV with V-Smile. Could the wires be replaced on the V-Smile?
Dec 10, 2007 | Televison & Video
Samsung HL-p4674 RB
Sir, Pull up the on screen menu and make sure the unit is set to display 1080i or 720p instead of 480i. This may be the issue. Good Luck
Jun 04, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
RCA F20TF10 20" TV Logo
26 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
