Question about RCA F32649 32" TV
Colour on screen out of balance due to magnetic disruption
I am sure there is something on the remote that allows service mode and that allows you to rebalance the colour guns.... can anyone tell me how do to this. A portable stereo was placed on top of the TV and the speakers seam to have disrupted the colour balance. If anyone can tell me how to fix I would really appreciate it. I don't really want to spend the money on a repair. Thanks
    Sergeant:
  • 280 Answers
You may be able to borrow a degauser from a local shop. If you can you turn it on and rotate it in a circular motion around the picture tube and back away slowly untill you see no effect. Turn it off and your done. You may be able to buy a small one at Radio shack. Bottom line is you have to use the right tool a magnet will only make it worse..
Posted on Jan 23, 2009
3.8l. Where is crankshaft position sensor located?
Here is a drawing and description of the location:
25974439-55j43zfoeuhdrtvntybmbhee-3-0.gif he CKP sensor, located on the engine front cover near the crankshaft pulley, is used to determine crankshaft position and crankshaft rpm. The sensor is a magnetic reluctance type which senses the passing of teeth on a tone wheel because the teeth disrupt the magnetic field of the sensor. This disruption creates a voltage fluctuation, which is monitored by the PCM.
Nov 22, 2015 | 2003 Ford Windstar
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
Monitor colour change
The discoloration problem is due to the near by magnetic field (magnetic interference or due to magnets) appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
Sep 05, 2008 | E-Machines e15t 15" Flat Panel LCD Monitor
Samsung vp-d351
proper focus in any camera will see colors ..or else record in b& w and in bad focus... make sure your macro mode is off and norm-auto on... most focus problems are due to dropping or stuck lenses.
night mode might mean your day sense has gone bad... the white balance etc.look for a default setting and turn it on.
larry
Aug 22, 2008 | Cameras
SHADOWS ON THE SCREEN
You left it on to long and burt the image of something else on there and ruined your monitor. Try to have your screen saver set to Ten minutes and turn it off if not using it for a while.
If its more like just weird discoloration, it may be that it needs to be DEGAUZED. to do this, use the monitor controls and select it from the options and press the button to degauz it, it will make a funny noise and wiggle the screen and then come back to normal. This may help or solve the problem depending on how bad it is.
Anything Magnetic that gets to close can do this to a monitor.
Keep out of direct sunlight and away from magnets.
Degauzing is bassically a small EMP pulse that will discharge magnetic field disruption do to sunlight or magnets.
Good luck.
Jun 12, 2008 | Computers & Internet
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Sd tv inbalance screen.
There is a code to get into service mode, but you should read over the service manual before you attempt to enter the service mode and change any settings. You can really mess up your set very easily. You can get the service manual at the link provided below, but you will need to register with the site to get it.
Link to site
Mar 13, 2008 | JVC AV-24F702 24" TV
Colour distortion at the sides of the picture
check to see if you do not have speakers on the side of your tv or any where around it.which could be causing your problem.
Jun 09, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
RCA F32649 32" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
