Hi:My TV will not turn on.I checked power to the set, it's fine. I opened the back panel looking for a reset switch, could'nt find one. Any suggestions?
Thank You for your help.
Power supply are available for this model it is on an exchange oly
Call me or send me the exact model number and serial number and i will be able to quote a price
Shuttle83, That is such a generic answer and I dissagree. If someone gets the schematic for this set they won't be able to tell a thing. They won't be able to read it as it is from China. I would suggest they take the back off and visiually inspect the power supply board. If the capacitors or puffed up at the top then they may want to try a power supply board.
An expert that got 10 achievements.
An expert that got 5 achievements.
Genius:
Master
Re: will not turn on
It sounds like you have a power supply problem.
I would suggest that if you are going to effect repairs on this unit yourself you get a schematic of the set and use a multimeter to test the power supply levels. This is good for a starting point, if you need any other assitance you can contact me or any of the FixYa experts to aid in additional troubleshooting.
Hi there- turn the tv off, then when turning back on hold the power button down for a short time - this should reset your television..
Failing that - unplug the tv (take care as residual power can remain inside - enough to cause a shock/ best to earth the tv before opening it) next take the back panel off - find and remove the back up battery - this retains settings while switched off- after a minute or two - replace battery and panel - thus should remove the lock
Hope this helps - failing these you should contact the manufacturer for a replacement remote
Resetting the TV If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE: Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1.Unplug the TV power cord from the power outlet. 2.Unplug any connected devices (DVD, Set-top boxes, etc...) 3.Press and hold the TV power button for five seconds. 4.Plug the TV power cord back into the power outlet and turn on the TV. 5.Open the on-screen menu to confirm that the TV is responding again. 6.Turn off the TV and reconnect the devices. 7.Turn on the TV.
There is a TV/VIDEO button on frond panel of the tv. When you press each time this button then you will able to access different video inputs. if the button is inactive the probably the micro switch for TV/VIDEO button may be faulty. also check the same with the remote. If its doesn't help then try to reset the tv to factory default setting. For that you need the remote. Keep in mind that when you reset the tv to factory default setting all the memorized parameters will erased(like channel memory, personal preference setting etc ). For reseting the tv to factory default do the following
1.Turn on the TV. 2.While holding down the RESET button on the remote control, press the POWER button on the TV front panel. The TV will turn itself off, then back on again. Release the RESET button
Just reset your tv to factory settings. By doing this all the settings will be set to its orginal factory mode, and you have to reset all the settings including V-Chip settngs. To set it to factory settings do the following.
Switch off the TV wiith its front panel power ON-OFF switch and wait for about 5 minutes.
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
Check the power source?Yes.Try tv unplug,replug it back an hour later.The tv now resetting it back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Before you Proceed, Disconnect the Power Supply, Unplug the Cord and then try to plug in after few minutes, say 30 minutes. If the Problem persists, more likely it's a Faulty Power Supply Board.
You need to have some electronic Experience to Open the TV and then you need to locate the Board. Once you find the Board, you need to pull the wires and try to Look for Swelled / Bulged / Leaked Capacitor. You need to go to Radio Shack or Order Online and then replace that. Once replaced, that would fix the issue. Usually, Bad Caps do have Ammonia kind of odor.
I am not sure if resetting the heater will work, or not, but it is worth a try! What you should do is open the right hand side door, find the POWER toggle switch and turn that off. Then find the Circuit Breaker for the heater and turn that off. Wait about 15 to 20 minutes, the reverse the order- Circuit breaker on, then the heater on. Try and start the heater.
If the error code comes back, check to see if there is glowing of the element. If not, turn over the Display Panel, there are Diagnostic Lights on the backside of the panel. If there is a light on next to a set of letters, that is whta is causing the issue with the heater.
NOTE: Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time. 1. Unplug the TV power cord from the power outlet. 2. Unplug any connected devices (DVD, Set-top boxes, etc...) 3. Press and hold the TV power button for five seconds. 4. Plug the TV power cord back into the power outlet and turn on the TV. 5. Open the on-screen menu to confirm that the TV is responding again. 6. Turn off the TV and reconnect the devices. 7. Turn on the TV.
Same problem. Can I just buy a new power supply and where at?
