Hdmi connector causes picture freeze
The connector from our panasonic bluray was originally HDMI. We experienced picture freeze requiring rebooting the TV. We have swapped out cables from a Monster to a Rocketfish with a higher rating and now we have ''speckles'' as well a picture freeze. We are now running with component cables and seem to be fine. However.. the optical audio cable running from the LG to our AVR no longer works so we're back to RCA's. Tried calling LG service and chat neither was available.
Thanks for any help
    Novelist:
    Scholar:
  • 67 Answers
The problems with HDMI are plentiful. They are still hashing out the standards for it, and every company seems to be doing their own thing. The compatibility issues are never ending, and you may be a victim.
It sounds like the Blu-Ray and the TV are having compatibility issues. You can try changing resolution settings inside the Blu-Ray to see if it helps. If not, you might be stuck using Component cables. LG televisions are not the most well-constructed or designed tv's in the world, so if the optical output is not working, your Digital Board might have an issue, as well. Any competent TV repair shop should be able to assist you in troubleshooting and repair, if necessary.
I hope this helps you.
Posted on Dec 30, 2008
What are the best settings for the DMP-BDT330 Panasonic Bluray Player
Hello Myles, we recommend you connect the player with a HDMI cable and then set the player's output to 1080p.
Apr 27, 2014 | Panasonic Televison & Video
Hdmi output and inputs are no working. Only one works and I have to use it for everything just unplugging it and plugging hdmi cable running from bluray or game into cbl
I understand from your original message the main HDMI output works, and only one of the HDMI input is working. Which HDMI input is working? Bluray, Cabl/sat, or Game? Are you able to select the working HDMI input either from the remote, and front panel of the receiver, or just from input of the receiver?
Double check your settings for Audio output and HDMI controls (found on page 36 and 37) of the owner's manual.
Jan 06, 2014 | Onkyo HT-S3300 Theater System
I have a panasonic 3d blu ray player with internet built in. I have my system wired to a hdmi switch and then onto wireless nikkai video sender to my projector this gives me a 100 hd inch screen with...
Try connecting the Bluray player directly to your projector and verify if you have the same issue. If you do not have an issue, your switch is causing the picture to freeze.
Aug 24, 2013 | Audio Players & Recorders
Panasonic PT-AE2000U All three HDMI Ports stoped working. I have tried different HDMI cable and a three different HDMI Feeds. I can get a picture using the red green blue component cable. Any ideas?
WOW. I just experienced the same thing. None of my HDMI ports are working, though component is fine. I've had my unit since November 2007 and had no problems until this. I think the HDMI board has gone bad and will require replacing.
May 20, 2010 | Panasonic PT-AE2000U Projector
Tv will not turn on. Flashes 10 times. If we unplug/plug it basck in several times we can eventualy get it to work. Seems to be getting worse every day.
You need to replace the power supply, PN: ETX2MM704MGH. This 10 flash failure is common. I hope this was helpful, best wishes.
May 12, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Plasma, panasonic viera
I had a similar problem with my Panasonic Viera 46 " 80U. I believe it was caused by HDMI ideoscyracies. When I turned off TV before shutting down the HDMI connected with my computer. It froze up. I could not get the TV to reboot, even if I pulled the plug, until I reconnected the HDMI to my computer and when I shut the computer down properly, something in the HDMI communicated to and released the TV from the freeze. At least that seemed to be the answer.
Let me know if this makes sense or if anyone experienced something similar.
Jan 15, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
When hdmi cable is plugged in bluray player stops
Since it was stretched check the ontacts on the acutal HDMI connector on the tv and the bd player a pin bent or touching another pin will cause a vast amount of issues
Mar 29, 2008 | Samsung BD-P1200 Blu-Ray Disc Player
Televison & Video Logo
794 people viewed this question
Top Televison & Video Experts
