Question about Goldstar MV-1526 Microwave Oven
Goldstar MV1526W won't run
Fan turns on and lights come on, but the turntable will not turn and it will not cook. Is it the magnetron or a board that won't kick it on?
  • 1 more comment
  • lgcrap Dec 26, 2007
  • donkell Feb 26, 2008
    The microwave won't heat. The turn table only turns when the door is
    open. The lights , buttons and fans work. There is no heat.
  • fah_bio Aug 29, 2008
    Mine is doing exactly the same thing...Fan and light works but no turn table and no heat. I have found that if I push upward on the bottom corner of the door it will work, but once released it usually stops working again.
    Any help would be greatly appreciated.
  • Goldstar Master
  • 9,098 Answers
It sounds like you have a bad door switch or mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts here: http://www.samsungparts.com/search/search.asp Door switches and other common parts should be available at local appliance parts stores and home centers.
Posted on May 01, 2007
Goldstar MV-1526W Microwave Oven caught fire over the control panel. The fire was on the connection to the LG Magnetron 2M214 can it be fixed?
take it to a repair shop for a proper diagnosis but generally anything other than a fuse , it will be cheaper to get a new unit
Jan 02, 2017 | LG Microwave Ovens
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
Microwave will not heat
If the microwave is 7 years old or less, there are too things that come to mind, defective magnetron, or the inverter board, cost should be considered when going ahead with repairs.
Jun 27, 2012 | Goldstar MV-1526 Microwave Oven
Goldstar MV1526W runs, turntable and fan turn, but does not cook
Thanks for mentioning the model number and detailed symptoms. That makes all the difference!
Since the turntable is running, the most likely problems in this case are a failed magnetron or a repairable bad connection at the F or FA terminal of the magnetron.
If there were a loud hum, that would also be either the magnetron or a shorted high voltage diode.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
We have also uploaded the service manual to our site here to help you.
Please note that the manual does not give you part numbers.
You can get part numbers and order parts for LG / Goldstar products from Encompass here or you can call them toll-free at 866-779-5835.
Oct 06, 2011 | Goldstar MV-1526 Microwave Oven
Microwave runs but does not heat or cook food
If a Goldstar, LG or Zenith MV1610 or MV1608 is running but not seeming to heat a load placed in center of turntable, its probably because the "stirrer" intended to spread microwaves generated by the magnetron around the cook chamber is stuck so that most all the heating is directed toward the back and top rather than the center of the cook chamber. This usually occurs after cooking for longer than a minute with no load in the cook chamber - as when a model w/o a timer (such as a MV1608) is intentionally operated in cook mode to serve as a kitchen timer, or when a model with a timer function (such a MV1610) is accidentally operated for longer than a minute w/o any load. Before assuming the magnetron (usually warranted for 5, 8 or even 10 years) or other high voltage component such as diode or capacitor needs to be replaced, try “cooking” a 16 oz pyrex cup of water at full power on the outer edge of the turntable for 2-3 minutes - which usually reactivates the "stirrer" and restores normal cooking function.
Jan 18, 2010 | LG Microwave Ovens
Oven does not cook
either your h/v diode h/v capacitor or the magnetron tube are faulty if the lights and turntable still operate
Oct 18, 2009 | Goldstar MV-1615 Microwave Oven
It is running, but doesn't heat the food.
I had the same thing happen to my microwave and the Magnatron was the bad part. There are some things that you can check and I would be glad to help. I bought the parts for around $70.00, but mine was a built in unit.
Let me know, I will help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a the highest FixYa rating (Give it Two thumbs up). If not then please comment to this post and I will try to help you further.
Thank you for your support.
May 21, 2009 | Goldstar Microwave Ovens
Sharp Carousel R-530CW
Hi, I am not sure of the cost concerning the control board, however, it does sound like a control board problem, or a door switch problem, I would need to see the specific unit diagram to know for sure, but many microwaves, not all, but many, have a door switch related to that part of the circuit, usually the fuse would blow at that point, but there again, it depends on the circuit. I would suggest you get the unit checked soon however. Hope that helps somewhat, and thank you.
Jan 24, 2009 | Magic Chef MCB780W Microwave Oven
Microwave does not head
Ok i had the same problem i took out the switch's and replaced the top one and it took care of the problem. switch part number is vp533aof i hope this helps you
Dec 11, 2008 | Goldstar MV-1526 Microwave Oven
Goldstar
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 27, 2008 | Microwave Ovens
Goldstar MV-1526 Microwave Oven Logo
1,298 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
