HTC G1 Logo
Posted on Dec 29, 2008
How to activate scanner application
I want to install the application to use a scanner for purchases
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jan 13, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
4648
Points
11
Get one application called barcode scanner or shopsavy.
2answers
NEED PRODUCT KEY FOR MICROSOFT OFFICE ENTERPRISE 2007
Sam,
If you are looking for a product key, even volume licensing, you will need to purchase the licensing. If you have already purchased the key but lost it and have it installed on a computer then you can recover it by using an application like Magic Jelly Bean. Otherwise it is into the abyss that is MS licensing.
5helpful
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
2answers
When the DataWedge 2.0 is launched, an Error "cannot set scan parameters 00000000" appears and scanner does not function. Was running just fine. MC7094. Scanning is working fine in another...
If the scanner is not working, you can try to go to this site to check the information on how to reset the device. Here is the link that you can try.
Thank you for sing Fixya.
Hello, I have a custom application but the scanner won't work with it. is there some way to enable the scanner to tell it to work. I have a quick scan sample app that works fine, but my custon app...
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
Is there a way to turn scanner on and off in a motorola 9090g. It appears it is only triggered in a application. I am trying to use the bar code scanner in a web based application.
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. You can also install the application DataWedge provided by the manufacturer. The DataWedge aplication will activate the scanner and the decoded barcode is sent as usual keypad inut to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
5helpful
Hello, I am with Motorola and have a MC5590. The scanner function does not appear to be working. I have version 6.5. Do you have an instruction set that can test the functionality of the scanner? Thank...
Hello Glenn,
to test the scanner I would suggest to download and install the Datawedge application. It is an desktop installation. As you will connect your MC55 to the Desktop per Active Sync the application will be installed also to your MC55.
The DataWedge aplication will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, if you scan a barcode a pop-up window will come up. Or if another application is running it will send the input to the application.
9helpful
I need symbol usb active sync rndis driver
Please install the Microsoft Active Sync application. After the installation is no driver needed for the MC9090 Mobile device.
6helpful
Scan bar code using motorola MC75
12helpful
Error message
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/ltkrn70n.dll/
as I registered few dll's from this site... pretty helpful...worked in my case :)
Scanner
Reinstall the software/drivers and try again.
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
