Question about Hitachi 61SDX01B 61" Rear Projection Television
Hitachi projection tv
Tried the manual convergence on my hitachi tv couldnt get the red lines to line up but also lost my magic focus do you know how to get it turned back on?
  • Hitachi Master
  • 3,459 Answers
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Posted on Jan 29, 2009
    Filmmaker:
    Uploaded 5 video answers.
  • 41 Answers
Posted on Apr 04, 2012
  • Hitachi Master
  • 5,138 Answers
Pull front cover off of TV behind there will be front of convergence board.With TV on- Press Switch in Front on board and your convergence Pattern should come up on screen
Posted on Jan 03, 2009
My TV is the Hitachi model 51UWX20B and tried using magic focus to line up red color. Picture looks like 3D with red off center. When using magic focus it gets to the red phase and it shows the number 5...
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
Jul 04, 2011 | Hitachi 51UWX20B 51" Rear Projection...
The color on the tv is messed up the green and red i tried auto and manual magic focus but cannot move the green line on manual magic focus please help
Most likely this set has bad convergence ic's and some open resistors. This is a common problem for projection tv's. Check:
resistors RK42, RK46,
RK50, RK54, RK58, RK62
Output STKs IK04, IK05.
I hope this helps. Thanks for using fixya.
Jan 13, 2010 | Hitachi 51F500 51" Rear Projection...
Hitachi 51-SWX20B Out of focus...tried magic focus and it stops on red. Tried manual focus but red lines won't move. How expensive is this going to be to fix. It is 7 years old and need to know if I...
YOU HAVE A CONVERGENCE PROBLEM. THE RED OUTPUT IS OUT. COMMONLY IT HAS BEEN FOUND TO BE THE DIGITAL CONTROLLER MODULE THET CAUSES THIS BUT THE OUTPUT IC SHOULD BE CHECKED FIRST
Dec 26, 2009 | Hitachi 51SWX20B 51" Rear Projection...
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
Convergence problem, I think
i think you need a tech .because all the users adjustment were tried.
May 28, 2009 | Hitachi 57F500 57" Rear Projection...
On magic focus the red lines are not lined up ,and looks like 3-D picture
hello, that is a  convergence problem .if you are in MD send me an email
caypianan@yahoo.com
May 24, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi 61udx10b
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
Dec 30, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Images have red and green outlines on them picture somewhat fuzzy
your convergence ic's are Shorted
They have a kit for this tv it is available through local parts distributors
If you can't find it locally just Google HITACHI CONVERGENCE KIT
If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
If you are not sure about doing this repair you should have your local tv guy do it for you
I
Nov 25, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Magic focus, #5 Manual
Sounds like a Convergence IC problem, the convergence ics would need to be replaced. This can be done by yourself or a professional.
Jun 06, 2008 | Hitachi 57S500 57" Rear Projection...
Magic Focus does not work.
Convergence issues usually resolved by changing convergence output amplifier IC's.....Original STK392-110 should be replaced
with upgrade Stk394-160E Hitachi part # CZ 01341,change both
for reliability.....check B+ feed resistors for over-heating....T.
Feb 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
414 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
