Question about Gb Electrical 1 30 Amp Ground Fault Circuit Breaker
One headlight is brighter then other
I have a nissan almera 02 plate. recently my electrical fault light lit on my dashboard and its on constantly. since then i've noticed one of my headlight is brighter then the other one, eventhough i have exactly same bulbs on both of them. its been like that for about three months now. can you please help? thank you
  • captainsal Dec 30, 2008
    tried it but still the same.
  • 8,197 Answers
Sound like the bulb is going out on you. I would replace the dim one and see if it fixes your problem.
Posted on Dec 29, 2008
My Nissan Almera keeps cutting out completely whilst driving?
run the fault codes and look for cam/crank position sensors.
faulty or loose connections may cause this fault. If you have more than 1 key in the ignition then it has been known that the mass of swinging keys will switch off the ignition
(current recall on all GMC ignition switches for just this reason)
Feb 13, 2015 | 2005 Nissan Almera 1.6
Where is the fuse bord of Nissan almera 1.6 2004 located
There are 3 Fuse panels in a 1.5 Almera : 2 are located in the engine bay beside LH+RH Main Lights,and both are Engine related,
The other is located below LH dashboard, once pulled a Grey Pocket.t(1.6 does no longer exist since 2000, by least in Europe)
Dec 14, 2014 | Nissan Cars & Trucks
I have tried to locate the TCM on a nissan liberty 2002 but cannot find it
ECM and TCM are both located under the dashboard, behind the glove box. You must remove the glovebox to access these modules. Remember that any yellow wires or connectors are for the air bags. You should probably refer to a service manual before accessing anything electrical/electronic.
Jun 08, 2014 | 2004 Nissan Nissan almera tino
Resetting after installing a radiator on nissan almera
Not sure on the Almera, but some vehicles need the light to be re-set with a scanner, it has stored the radiator fault in it's memory, trip to a garage I'm afraid.
Jan 21, 2014 | Cars & Trucks
Headlight and dashboard
try checking your alternator to see if its over charging your battery you can take it to your local pep boys or where ever you prefer and they can bench test it
Dec 07, 2013 | Cars & Trucks
Nissan almera loose clutch pedal
It sounds like the hydraulic clutch is failing or the car just has a light clutch feel. I suggest you have a local shop push the clutch and see what they think.
Sep 07, 2012 | Nissan Cars & Trucks
My one headlight is brighter than the other. It just recently happened. Not the fuses or wiring. Any suggestions? 04 Nissan Sentra
hi.
check the bulbs. one may have become loose, and is reflecting differently in the headlight appearing brighter, or you may have a bulb about to burn out.
if you swap the bulbs over, and it is still the same side brighter, then the issue is not the bulb but the wiring. if the brighter side becomes the dimmer side when you swap the bulbs, change both bulbs to make sure.
please feel free to ask for more advice if you need to fault-find on the wiring itself.
hope this helps
Jun 29, 2011 | 2004 Nissan Sentra
Headlights and dashboard light will not stay on at the same time. using the handle, at night, turning on the headnights, the dashboard lights will go out, clicking the headlights off, the dashboard lights...
check the dimmer adjustment knob for inst lamps.either its bad or you inadvertently turnud it all the way down.had the interior cleaned recently?they almost always accidentally turn it down.
Jan 17, 2011 | 2005 Nissan Altima
Gb Electrical 1 30 Amp Ground Fault Circuit Breaker Logo
258 people viewed this question
Top Gb Electrical Electrical Supplies Experts
Steve
ken skalski
Are you a Gb Electrical Electrical Supply Expert? Answer questions, earn points and help others
