Question about Dell Inspiron 8600 Notebook
My audio out port is only playing on the right side......the both speakers on the laptop itself plays fine
  • Anonymous Dec 30, 2008
    Hi! i have the same problem ... my Dell Inspiron 6400 had the same problem !!! HELP ME!!! XD
  • 192 Answers
You probley have the slider on one side insted of in the middel for the master volume control
Posted on Jan 02, 2009
My laptop plays sound out of both my speakers and headphones.
It sounds like that port is set to mono, go to properties and check that.
Jan 10, 2015 | HP Pavilion Computers & Internet
Why won't my hp elitebook 8540p speakers work while in the docking station, connected only to external mouse and monitor?
You can switch audio playback between the docking station and your Surface speakers. Here's how:
Step 1: Swipe in from the right edge of the screen, and tap Search.
(If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.) Step 2: In the search box, enter manage audio, and in the search results tap or click Manage audio devices. Step 3: Next, do one of the following:
  • To play audio through the audio port on the docking station, tap or click Speakers (CNXT Audio).
  • To play audio through the Surface speakers:
    • On Surface Pro 2 or Surface Pro 3, tap or click Speakers (Realtek High Definition Audio).
    • On Surface Pro, tap or click Speakers (2-High Definition Audio Device).
Step 4: Tap or click Set Default, and then tap or click OK.
http://globalvision.com.vn/vn/may-in-ma-vach-pc-3.htm
Apr 27, 2014 | HP EliteBook 6930p Notebook PC
Magicjack problems
Magic Jack stores your messages as an AUDIO FIle. You play them back via Microsoft's player program. If your audio program is not working, then you can not play them back. Check and see if you can play a music file from the sample music folder. It works OK, then Windows Audio is fine. If not you may have turned off the Audio. Look to the lower right side of the computer screen and you will see a small speaker. Left click and see if the VOLUME is set to an audible pitch suitable to you. Check the master control and make certain it is on, set to the type of speakers you use. If all the settings are correct and the sound level is OK, then you should be able to play back your messages. Write back if you still have the same problem.
Jan 01, 2014 | Computers & Internet
No volume when playing movies
The Problem> Sound: Placing the mouse pointer over the ICON to the lower right of your screen should indicate the percentage of Volume your speakers are adjusted for. Right click and you get the Open Volume Mixer section. The playback devices can be your computer speakers or a separate headset with microphone. Here you can make adjustments accordingly. At the bottom are Volume Control Options that allow you to increase or decrease the audio reception. Generally, when you insert an external Headphone with Microphone into the sound port in; an automatic disconnect may occur preventing computer speakers from working. This is common with Laptops. If you lack sound, you may need to update the sound drivers, change cables, and/or check to see if the speakers work on another device.
Dec 27, 2013 | Toshiba satellite c660
Audio will play on internal speakers only
Are you plugging the external speakers into the right port? Try plugging them into the Headphone port if there is no external speaker port. Make sure you have the external speakers turned on and the volume turned up. Also make sure you have the software in the computer to have the volume turned up and not muted. Check the audio sound properties and make sure the volume is turned up and not on mute.
Click Start/Control Panel then look for Audio or Sound and check the volume.
You can also click the megaphone at the bottom right near the time to adjust the volume and check for mute.
May 12, 2012 | Dell Inspiron Mini 10 Notebook
Can a Dell Dimension 3000 connect to 5.1 surround sound
If your Laptop has a "Latitude C/Port Advanced Port Replicator" Then this Port Replicator connects Dell Latitude notebooks to peripheral devices such as a monitor, printer, keyboard and mouse. To accomplish this, connect your peripheral devices to the Dell port replicator itself, and leave them connected to it. Then connect your notebook to the port replicator to access the devices without having to attach them individually each time you want to use them. You can also set up speakers on the Dell Latitude C/Port port replicator to provide improved quality audio.
Follow following steps:
1) Place your Dell Latitude notebook in your C/Port Advanced Port Replicator and turn on the notebook using the power button.
  • 2) Place the speakers you want to connect to the port replicator on either side of the port replicator according to the Left and Right (L and R) labels on the speakers.
  • 3) Plug the audio line connector from the speakers into the audio line out plug on the port replicator. The audio line out plus is on the right-hand side of the port replicator base next to the infrared port, directly opposite the notebook ejection lever.
  • 4) Plug the power cable from the speakers into a power outlet if needed. Battery-powered speakers will not require this. Turn on the speakers following the manufacturer's instructions.
  • 5) Open your preferred music or audio software (such as Windows Media Player or iTunes) on your Dell Latitude notebook and play an audio file to hear the newly-attached speakers.
  • Dec 01, 2011 | Dell Dimension 3000 PC Desktop
    Remote speakers don't work
    Dear User,
    Are you referring to playing music from another device (mobile phone) into the speakers of your laptop or vice versa?
    Is yes then you must first switch on the Bluetooth on your laptop as well as mobile, if playing from phone you send to use the option play via Bluetooth in the phone, simultaneously accept the pop up options as yes on the PC to enable the wireless play.
    If playing from PC to wireless speakers of mobile then right click on the on the bluetooth icon near the system date, select quick connect>> hand free audio/stereo audio/audio gateway as applicable>> find devices in range and select to play, also simultaneously accept any notifications if displayed on the phone.
    May 03, 2011 | Acer Aspire 5050-3242 Notebook
    Sony str-de875 amp. one speaker louder than the rest
    hi. i have a sony amplifier. i plug the speakers in like normal. i turn it on and the right side speeker works fine. but you half to crank it up all the way just to barely hear the left speeker. we switched speakers and its still the same effect. we think its the amp itself. we tried our balance settings. it was fine. but right now its just playing one speaker louder then the left one. can anyone help me?
    Apr 03, 2008 | Sony STR-DE875 Receiver
    No Real Time Sound from USB Port in Headphones
    The problem is due to the design of the DELL Laptop itself. It is not dsigned to monitor the incoming signal. I bought a cheap Behringer UCA202 USB-Audio Interface. It provides for real time monitoring the incoming sound. I can also hear the accompanying music while I play along with pre-existing tracks. It's not the highest quality but it was only 25$ so well worth the price.
    Oct 18, 2007 | Compaq Presario Notebook
    Mp3 player only plays on right side speakers
    Have you tried a different jack? It could be faulty.
    Aug 11, 2007 | Pioneer DEH-P6800MP CD Player
    Dell Inspiron 8600 Notebook Logo
    18 people viewed this question
    Alun Cox
