Question about Toshiba Tecra A4 Notebook
Open Question Hi I have a toshiba a-100 laptop bought 2 years ago, and it stopped to respond to the spacebar, all the arrowkeys and fn button.I am using the onscreen keyboard for the above keys funcionality. I confirm the keys are not sticky.please help
Vgn-nw150j keyboard Sony Vaio many keys stopped working all of a sudden need help?
Laptop keyboards do deteriorate from time to time. Once any key stops working, it is time for a replacement. Doing so is not difficult. Simply undo the case screws and gently separate the case to expose the keyboard. The keyboard floats inside and lays in the main board. Lift gently and pull out the small flat wire connection. The keyboard slides out and replace with a new board. Place flat cable in port on the main board, lay keyboard on top of chassis, close the top/bottom of case, tighten screws and all done. Go on line for Keyboards.
Feb 04, 2018 | Sony VAIO VGN-NW150J/S Notebook
Reset password cmos toshiba satellite A65-s1064
The only way to reset the cmos battery is to remove the battery from the back, open the bottom of the laptop and remove the button battery for 3-5 minutes. Replug in the battery and close up the case. Once completed, you can then create a new password.
Apr 08, 2011 | Toshiba Satellite A65-S1065 Notebook
I bought a new Toshiba laptop 2 years ago, but didn't get my key to unlock the system in order to buy and download Windows programs from the internet. Is it possible to get a new code / key to unlock my...
Hi Petrina,
Please advise what model is your laptop so we can help you download Window compatible to your unit. If want, you can also visit Toshiba Customer Service
Jul 27, 2010 | Toshiba Computers & Internet
Fn and spacebar make icons really big
Hi, right click on the Desktop Screen; select from the "View Icon sizes in the window, "medium, small..." If the solution helped, rating it is appreciated, thanks
Mar 18, 2010 | Toshiba Sattelite A105-S2071 Notebook
I bought an emachine computer in January. 2 weeks ago the keyboard quit working. I tried another keyboard and that does not work either, what do I do.
to find the problem with key board & mother boarb Slot....? if u r key board usb port than conect another port restart the pc. key board not responding and the problem with key board. replace it
Mar 18, 2010 | E-Machines eMachines Desktop PC
Spacebar not responding on Toshiba laptop Satellite
Since the spacebar is the most used key on the keyboard, it is likely a hardware failure of the spacebar itself. Replacement keyboards can be found on EBay and normally run about $20
Jul 05, 2009 | Toshiba Satellite M45-S331 Notebook
Some keys are not working
we are fashing this type of problem same time Ago and we are resolve it fist of the Remove The keyboard and clen for isoprofile and reistall aftert all key are working fine.
May 01, 2009 | Toshiba Satellite A135-S4467 Notebook
use a compressed air can to clean under keyboard.
Jan 11, 2009 | Packard Bell Easy One Silver 2120 Notebook
hi it sounds like the laptop key board has a fault try going back in to your region settings and putting in your correct region place eg uk or usa or even restoring defalt setting this will be in your control pannel ok if this dose not fix your problem then you may need to take it to a pc shop for a new key board fitted .
hope this helps thanks and all the best
May 22, 2008 | Computers & Internet
Toshiba Tecra A4 Notebook Logo
277 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
