Question about Crosman (4032)
Does not hold air as you pump
1966 crosman 760
  • gflnt Apr 05, 2009
    I have a crossman 760 that does not hold air as I pump, therefore due to the lack of air pressure I am unable to fire.
The neoprene bushing is worn out
Posted on Dec 30, 2008
Been sitting for a year, it willnot hold air to shoot, I pump it up 10--12 pumps it won't shoot
Most likely needs oiling. See illustration. The Pump Cup may need some time to soak up the oil. If it is extremely dry it may take a bit more oil than recommended.
Jan 15, 2016 | Crosman 760 Pumpmaster Air Rifle
Daisy Pumpmaster 760. How do I reassemble?
PDF]OWNER'S MANUAL - Crosman
www.crosman.com/pdf/manuals/C760-OM1.pdf
Crosman Super. ' Pells® or Crosman Super. BBs®. Reservoir ... 'WARNING: Pelletsshould never be-put F'6_ into the BB Loadlng Port . They will iam ... BB How To Load Your 760 Rifle with ... see REPAIR SERVICE section of this manual. ' '.
Crosman 760 Pumpmaster assembly - YouTube
? 3:56
https://www.youtube.com/watch?v=OeOLKDYnGoE
Nov 16, 2008 - Uploaded by stonie stonemaker
Crossman 760 Pumpmaster air rifle in pieces? ... I can't close the bolt there's a little metal part that's not ..
Dec 25, 2015 | Optics
My granddaughters 760 pump master will not hold air pressure. When you pump the handle it makes a funny noise such as rubbing the side of a ballon filled with air. The BB just falls out of the barrell. Can...
Hello, I'm not sure why you wrote under this other guns listing. The Crosman Phantom .177 Caliber Break Barrel Air Rifle is a single break action pump and it only shoots Pellets. also much nicer than the 760 pump master, but, it also costs more than 2x's as much.
as for your problem with the 760. sounds to me like it was not maintained well. If You have tried this already ( Crosman Pellgunoil® Air Gun Lubricating Oil ) and it did not work. You can assume that little BB gun is probably broken, the air compression chamber have popped a seal most likely.
if You haven't tried that, oiling the gun then I suggest doing that and maybe it's not too late. There really isn't a lot to be done on these cheaper models of BB guns.
if the BB gun is not years old, just purchased, and Amazon buy, or something else cool like you have a wal mart receipt for it or even if you don't have a receipt and you just want to exchange it. ( i will explain that in a minute ) then I suggest you try sending it back.
If You bought it at a store`, you don't have a receipt. do this if you feel you did nothing to deserve this broken gun.
go back to that store and buy another one, exactly like that one. with cash or card. save your receipt, take the gun home, get it out of the package and use it and take care of it according to the directions. in a day or two take the broken one and the box from the new one back to the store and tell them you want a refund and they will credit your card back Or if you paid cash they will give your cash back. This method of return eliminates the possible bad mood or cranky manager that COULD turn your request down because of no receipt.
This is a great answer to your problem isn't it? :O) Hope it helps.
Mar 09, 2015 | Crosman Phantom .177 Caliber Break Barrel...
I work the lever to load one BB. then pump 6 or 7 times. BB will not shoot out. When I pull the trigger, it sounds like it is shooting, but no BB comes out. this is for a crosman 760 pumpmaster. it...
Can you see through the barrel? Or run a rod down the bore? It sounds like the BB is either falling out the end of the barrel or the BBs are getting jammed up in there. Do not hold your hand in front of the barrel to see if any air comes out. You might get stung with 10 BBs. Hope this helps.
May 22, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
Hello, i have a Crosman 760 Pumpmaster Air Rifle, i got it from my grandfathers basement and it does not hold air pressure, i dont know what year but its the old one with the brass bolt, not plastic. i...
Sounds like it has a bad o-ring. you can take it apart and replace the o ring for under a dollar. just make sure you look at how it goes back together when you take it apart they are very simple. just make sure the carefully take the right side cover off with the left side of the rifle laying on a table, everything should stay assembled this way so you can look at it. the part you are looking for is in the large chamber that the pump goes into. from the back (the side opposite the pump) remove the spring and the metal piece behind it, then use something the shove the big brass part out of the chamber and the o ring is on the big brass part . take the old o ring to a hardware store to get another one.
Feb 08, 2010 | Crosman (4032)
Crosman Powermaster 760 pump bb gun won't hold an air charge
Take a look on amazon Amazon com Crosman Powermaster 760 pump and take a look for replacement. have a nice day
Feb 12, 2009 | Crosman (4032)
Powermaster 760 b-b repeater/177 pell. gun.
go to www.crosman.com and they have a parts list that should help in getting the parts needed for replacement.
Oct 01, 2008 | Crosman (4032)
CROSMAN 760 PUMP PELLET RIFLE REPAIR
How do you change the air cylinder
May 26, 2008 | Crosman (4032)
Crosman airguns 357 6 shot
What part are you having trouble with?
I have had mine apart several times trying to repair a leaky valve.
Could possibly make a you tube clip.
Dec 26, 2007 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Crosman (4032) Logo
372 people viewed this question
Top Crosman Optics Experts
Anthony Coots
Anthony Coots
Level 1 Expert
Martin Clarke
Martin Clarke
Are you a Crosman Optic Expert? Answer questions, earn points and help others
