Question about IBM ThinkPad 600E 2645 Notebook
Have IBM Thinkpad 2645 which refuses to start. Error 163 appears
I have reset the time screen (many times) clicked on OK and after the 1st screen appears computer beeps twice and then returns to the date screen. Have searched the internet and some sites have downloads that say will fix the problem, but I cannot start the lap top to download.
  • 1 more comment
  • rwhitney Jan 03, 2009
    mine does not go back to the time thing, it goes to this thing where it appears to show the power icon, and an arrow pointing to a line, and it will sit for hours doing that until i shut it off. email me at rwhitney.co.nr@gmail.com with an answer please
  • Anonymous Jan 10, 2009
    This is Vijay and have the TP 600E related problem on the site.
    Now here is a run down of my situation:
    Just like many out there I have the
    Error code 00174
    DEU 001
    Error 91
    FRU 3610
    appears to be very common but workable problem I'm about to follow some of the advice out there and see how it works out.Meantime any input on the Bttery Pack cost and retailers?Looking for one in Canada..South-western Ontario?Pls help secure peace of mind..
    On the start up there was an error code 174 (started about Sept 21st)
    Investigating the same thru self diagnostics found additional error msg ?
    DUE001 and 91 and FRU3610.Also High Voltage and Battery too hot.
    Research indicated errors relating to Battery Back up CR2025
    Further research /advice indicated remove CR2025 and restart
    Followed up and error codes were gone but 174 continue to be there every time
    Restart generated 174 again and directed to error diagnostics again
    Reinstalled CR2025 and battery pack 02K7018 reset the clock and date.
    Running the test various times(including the loop test)even after reistalling the earlier removed CR2025 and 02K7018, all tests come out OK
    Continue to get 174 on every star-up? including start-up from F1
    Error code refers to confugration related problem?System Board tests came-up OK.
    Do I need to replace CR2025 with new battery and/or battery pack 02K7018(That is an expensive proposition for some one on a budget)
    Do I need to reload the operating system that may clean up the confugration problem?
    Your input and early help will be much appreciated.
    Many thanks in anticipation.( sorry but UR e-mail was rtd undelivered.)
    Yes after you remove the battery the error codes are gone and test will indicate OK for all aspects of testing but still have problem with error code 00174.Advance/loop testing fails to indicate results for HDD?Error code 00174 relates to confugration ?
    Any suggestions/advise?
  • Anonymous Feb 16, 2010
    windows installation process issue
    halfway thru the window runs up to accept enduser licence agreement and after than setup incomplete cuz system can't find HDD even though the toshiba 20gb drive shows in scan while uploading and checking system info?
    test shows HDD OK
    changed the CIMOS battery a cpl dayz ago? and now don't need to reset the date n time cuz I was getting error codes for that reason.
    remived drive and cheched on desk top formated and is clean drive
    now the window set up comes with error sbp2port . sys is corrupt?
    any help will be much appreciated..look forward to your prompt assist plz..
    Problem Solver:
  • 10 Answers
Try replacing the cmos battery
Posted on Dec 30, 2008
I have ibm 600e 2645...error 161 and 163....Replaced my bois battery and still get the same error. I reset the clock and I still get back to the OFF and ON site which leaves me nowhere
after the error you need put the right date and hourly push ok later hold the button to off - turn on if the problem continued is a motherboard problem
Mar 18, 2010 | IBM ThinkPad 600E 2645 Notebook
Error 163 173 ibm 600e laptop when turned on these errors occur
this error is the battery by the sound of things, you need to replace the cmos battery , then enter the configuation utlity and set date and time, hope this helps
Nov 29, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM THINKPAD 600 - How to fix error codes 161 and 163
START WITH THE MACHINE OFF
HOLD and CONTINUE TO HOLD "F1"
WHILE STILL HOLDING "F1" TURN ON THE MACHINE
AND
This will go into bios, you'll get a green and white screen.
Set time and date there, save and exit.
Should work.
Mar 17, 2009 | IBM ThinkPad 600 Notebook
Numerical Error Code 161 and 163
have you tried doing it in BIOS? coz the battery causes that
Mar 17, 2009 | IBM ThinkPad 380ED
Starting ibm thinkpad
Errors 161 and 163 mean the time and date are not set in the CMOS. This typically means the CMOS backup battery is dead / going dead.
Mar 05, 2009 | IBM ThinkPad T21 Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Error message
the bios battery is dead and your machine is losing the date and time when u shut it down. you can get one on ebay for about 3 bux
Oct 05, 2008 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Boot sequence
161 and 163 error means you have to change your CMOS battery. open the laptop, change the cmos battery and you should be able to set the date and time.
after which you can access the bios by pressing F1 upon boot up and change the boot sequence after that
Mar 30, 2008 | IBM ThinkPad 380ED
Error codes for ibm thinkpad 600E
Your bios battery needs replacing
http://www.bioscentral.com/misc/ibmdiag.htm
Hope that fixes it for you? :)
Jan 06, 2008 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
396 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
