Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have a RCA D56D20 tv will not power up it blinks three times
You hear a cherping noice coming from the back. I have replaced the CP 120 cause it was bubled up. Where do I need to go I am really lost. Please help
  • RCA Master
  • 5,138 Answers
You have 2 more caps in same circuit you need to replace cp114---cp120 both are 220uf 35v. Also chirping nosie means Shorted hori output NTE 2324 .On second ribbon on deflection board make sure it is connect good or it will make a squealing noise and TV will not come on. Happy New Year.
Posted on Dec 30, 2008
When power button pressed get three blinks accompanied by a squeal with each blink. I replaced capacitors CP 130, CP 120 and CP 114. I removed CP 150 and verified it good with meter. I replaced fly
Your Set Is In HV Shutdown,Probrably Caused By A Shorted Flyback Transformer & Horiz Output Transistor,With That Model Rca, These Items Are All On One Separate Module Or Board,Which Can Be Purchased Seperately..
Sep 24, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
When power it'll blink three times and shuts off
It is probably the power board. When the capacitors on the board fail they can make a hissing noise. If you look at the board and the small cylindrical things on the board ( which are the capacitors) are bulged on top instead of flat this indicates a failed capacitor. The board should then be replaced. Hope this helps.
Jan 01, 2014 | RCA D52W19 52" Rear Projection Television
My RCA D52W14 wont turn on it makes a weird noise and the power light blinks as it's making the noise three times than the blink stops and noise too
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. 3 blinks occur if any of them is puffed up on top. To resolve this issue you'll have to replace all the 3 capacitors CP150 2200UF 16, other 2 are 220UF 35v they will be green with gold writing on them. Also re solder all pins on Fly Back Transformer (FBT). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 12, 2010 | RCA D52W19 52" Rear Projection Television
52" rca hdtv monitor power flashes 3 times after pushing it and tv does not turn on.
Hi
Thanks
Rylee
Aug 10, 2010 | RCA R52WM24 52" HDTV Projection Television
The tv will not power up. Blinks three times and shuts down. TL010 shorted ,replaced but still has problem.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If any of them is puffed up on top replace all the 3 capacitors CP150 2200UF 16 other 2 are 220UF 35v they will be green with gold writing on them. Resolder all pins on Fly Back Transformer (FBT) also. FBT could be in the power supply. Check the SMPS and in any event replace CP 120: 330UF/35V/HF & CP 150: 2200UF/16V/HF (May be bulged or vented)
Always Resolder Cl031 & Cl032 (usually looks ok on visual inspection but common to ring crack).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 06, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Have a hard time turning on my TV, have a RCA big
there are caps in the smps board that require replacment cp 150 cp 120 cp114 and check solder connections at clo32
Oct 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20
it should if you can get one most have been on back order. the board with the ihvt on it is the one to replace
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
3 green blinks
Look on Deflection board cp 150 2200uf 16v capacitor and there is 2 more capacitors 220uf 35v replace both of them. Green and Gold writing on caps.
Sep 09, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
