Question about Jwin JD-VD625 System
How to connect this entertainment system to existing sony recieve
I just purchased the Jwin JD-VD625 and I want to keep using my Sony receiver because we listen to our Sirius satellite radio through the receiver. The directions only show how to hook everything up to the television, but it doesn't mention a receiver. Any suggestions? Thanks
This is a standalone system. It can't be used with a receiver. Sorry.
Posted on Apr 14, 2009
How do I connect Sony S590 3D Blu Ray to Analog TV & Sony DAV-DX255 Home Entertainment Center
It depends what connections the TV has. If it has HDMI sockets then you should be able to connect the player via one of them. The sound should be connected using an optical lead from the player to the Sony Center.
However you will not be ever be able to play a 3D movie till you have a 3D TV. It will simply not work.
So at the moment you have purchased a an expensive 3D player which can only play back normal Blu-Ray's and DVD.
Feb 04, 2018 | Sony BDP-S590 3D Blu-ray Disc Player with...
I have jwin jd-vd503 it does not work it shows
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
  1. (Open the disc tray)
  2. Press SETUP
  3. Press 1, 3, 6, 9
  4. Press LEFT 3 x
  5. Press RIGHT
  6. A new menu entry appears (Version)
  7. Select it and select RC (0=codefree)
Sep 15, 2009 | Jwin JD-VD502 DVD Player
I have just purchased a home cinema system: SONY 46" LCD, KEF3005 SPKS, SONY STRDA2400ES RCVR, SONY S55O BLURAY. ALSO A VIRGIN HD+ BOX. CAN YOU ADVISE BEST WAY TO CONNECT THIS ALL TOGETHER FOR BEST...
connect all source devices to the Sony LCD tv inputs. and connect the audio output from the tv to the aux input or any one input of the audio reciever. This way you can just leave the av reciever on and control all the input switching with te tv remote. Avoid connecting all the av sources to the reciever and the tv as a monitor from the video out of the av reciever. Just use the av reciever to reproduce the desired audio and do all the input switching with the tv remote. This will simplify the operation an lessen the chance of someone changing the audio settings of the av reciever.
Aug 29, 2009 | Audio Players & Recorders
Wrong region
I just found this answer from another contributor.
Turn the power on
Close the drawer
Press 9735
Select Region 0
Exit Setup
You now have a multi zone DVD
Mar 17, 2009 | Sony Televison & Video
Upgrading dvd to blu-ray - how can I use my existing surround sound speakers?
Unfortunately because your existing system does not have the option of connecting an external source, such as another DVD player, the only option you have is to reuse your existing speakers and purchase another amplifier. Trying to patch another DVD into your existing unit would require a bit of technical expertise which would be more trouble than it is worth. The all-in one concept is convenient but very limiting in terms of expansion.
Oct 11, 2008 | Sony DAV-DZ100 System
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
Jwin JD-VD625 System Logo
83 people viewed this question
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Oloyede Monsuru
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
