Question about Panasonic PV-GS31 Mini DV Digital Camcorder
Newly Inserted Tape Ejects Automatically
What would make the camera not accept any DV tapes? If a tape is inserted, the door is closed, the camera just automatically ejects it. I hear movement inside but it is difficult to tell if the tape is being pulled out of the cartridge or not before ejecting. I have tried multiple tapes and checked write protect switch...etc. cannot find anything that makes a difference. The camera has worked for a couple of years. These tapes have all been used previously and I know they are good. Thanks for your thoughts....
  • 76 Answers
More than likely either the capstan motor or the drum motor are not turning and tape wont load.have you tried reseting by removing battery and reattaching,this sometimes resets micro and all will be fine.If this doesnt work is a job for technician,.
Posted on May 15, 2007
    Scholar:
  • 125 Answers
Usually the drive mechanism is made up of rubber rollers, belt, etc. If these are worn out (in time), the drive mechanism will slide and will not be able to rotate the tape. If the cam cannot detect the movement ?n the tape then it will efect it.
Conon zr200 tape loading assembly will close with no tape in but will not close with tape in carriage
The tape transport mechanism cannot fully engage the tape to the head. When a tape is inserted, the tape guides have to pull the tape from the cartridge and send it towards the head. There is a sensor in the carriage that activates the transport to perform its' job. When that sensor is not enable, it will just allow the door to close and the tape guides will remain stationary. Basically, it needs to be taken apart and fixed or realigned.
Nov 13, 2010 | Canon ZR200 Mini DV Digital Camcorder
My Sony DCR-TRV33 won't accept a cassette. It will close itself up without a cassette tape in place, but not while a cassette is inserted. I have tried several different tapes, so it is not the cassette.
Hi wnwatkins3,
Have the same problem here. Bought my TVR33 in 2003, and its still
a good cam with 1 megapixel. But since 1 month the tape won't load. I can insert any tape in the cassette, but it won't close. Without a tape it closes fine.
My only option is to send it to frsbenelux to fix it for a few hundred euros. Hoping to find a solution on the net, i will share with ya.
greetz Ed
Jun 29, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
Canon es55 video camera. Everytime I put a tape in, it ejects it. If I take the tape out, and close the door,it will will automatically close and stay closed
Nov 21, 2009 | Canon ES970 Camcorder
Canon ZR200 -- I can no longer get the camera to accept a tape.
it could have been forced at some time and has bent the loading door,,, maybe a bit of cassette broke off inside it and is jamming it up best bet is to drop it off at the repair shop let them fix it for you,,
Oct 27, 2009 | Canon ZR200 Mini DV Digital Camcorder
I can no longer get the camera to accept a tape. It ejects the tape after I insert it. The tape housing never closes back into position like it should.
the camera just could have worn out, fixing this would be pretty hard.... but if you want to unscrew the screw and make sure all the connections are intact and find the tape head and wipe it off with clean gym shorts. then make sure all the gears are in the right place
Tape not loading
Drop it on a carpeted floor from half a metre
I got the solution fromFixYa on 3rd Feb 09 it worked for me
Dec 16, 2008 | Canon DV-MV830i Mini DV Digital Camcorder
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Canon MVX200 will not load dv tape
The "remove Tape" error message on Canon DV camcorders is a general message meaning something is not correct with the tape transport system. These are miniature precision mechanisms and It could be anything from dew sensors to head motor, capstan drive etc. If the cassette drawer closes OK with no tape inserted then the tape sensor/ end tape sensor is operating. With no tape inserted the head drum does not run when the drawer closes but it does with a tape present. Does the head drum start up when you load a tape or is there no noise at all? If the head runs then it is possible the capstan is not starting or is jammed. If the head does not run then the cure will be either extremely tedious and delicate or very expensive. These units do not dismantle easily so unless you have some experience with this, or are willing to take a risk, then I would not recommend it. However, without such action you may have to write-off the unit anyway. Canon's repair charge will exceed the camera's value unless it's still under warranty. Your best option would be to find a local repairer that is willing to look at it, but I wouldn't be too optimistic .To some, this error message is a major issue when deciding to buying canon dv cameras. However, they are great little cameras and treated kindly will give many hours of excellent service. Don't store the camera with tapes loaded. don't subject it to sudden temperature changes or excessive vibration. Store it in a dry protected atmosphere and refrain from taking it onto the beach (salt AND sand !!!!) when on holiday etc.
Dec 17, 2007 | Canon MVX200 Mini DV Digital Camcorder
Panasonic PV-GS31 Mini DV Digital Camcorder Logo
224 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
