Question about Logitech iTouch (Y-RC14-PB-N )
Accidentally programmed keyboard
My buddy accidentally programmed his Logitech Y-RC14 keyboard. The U key does CTRL+TAB, other keys do other weird things. It isn't batteries, we also restarted the PC, pulled the batteries while the PC was off etc. Any thoughts, or a link to a manual would be greatly appreciated. - Joel
  • helpme368 Jan 06, 2009
    Thanks Yooperbud! I will look at your suggestion. A recommendation I found said that pulling the battery and typing continuously for 2+ minutes would drain the power. What we did for a solution was to replace it with a wired keyboard for 24 hours. In those 24 hours, we pull the batteries and ignored it. When we pluggesd it back into the PC, it worked fine. Thanks for your advice.
    President:
  • 8,637 Answers
Did you try going into Control Panel and then clicking on the Keyboard icon. Next click on the key settings and then you can re-program the keys to work as you need them to. Bud
Posted on Jan 05, 2009
Used ctl,alt,page up to reverse screen....cant get it back!
Using keys on the lower right of the keyboard, reverse the process. For instance, if you accidentally pressed CTRL + ALT + HOME to turn orientation upside down, press CTRL + ALT + END to turn it right-side up. Likewise, if you pressed CTRL + ALT + PG UP, press its opposite, CTRL + ALT + PG DN.
Aug 10, 2013 | Computers & Internet
Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
You might have "sticky keys" so try this:
When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
    • Press the "Shift" button five times in a row to turn off sticky keys.
    • Open the "Start" menu and then click "Control Panel."
    • Click "Ease of Access Center" from within the Control Panel window.
    • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
    • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
    • Click "Apply" to save your changes and then click "OK" to close the window.
Hope this helps. Good Luck!
Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
Pavillon ze2000 mousepad was accidentally deactivated now I can do nothing even with the keyboard. How can I get into the control panel and coc this problem?
Logon to the computer, Press the windows logo key on your keyboard and use the arrow key to navigate to control panel, go to device manager use a combination of the tab key and the arrow key to navigate to the mouse and pointing device and enable the mouse.
Sep 03, 2010 | Computers & Internet
I have a Microsoft Digital Media Keyboard 3000. I
ctrl + alt + one of the direction keys (i believe hitting down will return it to normal)
Jul 09, 2009 | Microsoft Computers & Internet
Keyboard types things that I don't type or opens new windows
Your hand is probably just hitting the CTRL key accidentally when you type; I had the same problem and pried off the CTRL key and have had no problems since.
Jul 01, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
F keys suddenly not working
The "F mode" button toggles on and off the F keys. If you press it (accidentally) as I did, the keys will no longer function.
Simply press the "F mode" key again (it is directly above the "End->" key between F12 and Insert on this model keyboard) and functionality will be restored.
Apr 08, 2009 | Logitech Computers & Internet
KEYBOARD QUIT
Problem solved by a representative at Logitech. press (at same time) Alt-ctrl-f12 two times, press reset on receiver, oress connect on back of keyboard then esc.
Dec 02, 2008 | Logitech Cordless Desktop EX110
Logitech cordless keyboard erratic after cleaning keys
seems to be that you may have accidentally swept some dirt underneath the keys.
try pressing each key individually in word and narrow down the affected key or keys, then remove the affected keys (using a keyboard key removal tool, or very carefully by hand) and clean underneath the key with a small dry clean brush both under the key and the board section it lay in, then replace the key and type the key again, if that has no luck then try the process again.
hope this helps
kev
Dec 01, 2008 | Logitech 967437-0403 Keyboard
KEYBOARD CHANGED MONITOR VIEW TO HORIZONTAL... NEED FIX
Try hitting "CTRL + ALT + An arrow key"
That should flip you right back!
Oct 03, 2008 | Logitech 967437-0403 Keyboard
Logitech keyboard won't work
My key board stopped working. I replaced the batteries and I have know use of it. It will do nothing.
Jun 09, 2008 | Logitech 967437-0403 Keyboard
Computers & Internet Logo
241 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
