Question about Denon AVR588 Receiver
No sound when ps3 is hooked up to a denon avr 1609
I bought a denon avr 1609 yesterday and when i hooked it up to my ps3 there is no sound. is this reciever not compatible with the ps3? or am i not doing something to make the optical not work?
The 1609 only has video on the HDMI. No audio comes through the HDMI cables. Hook up an optical cable between your ps3 and the receiver and you should be good to go.
Posted on Jan 11, 2009
I am trying to connect ps3. (bought may 2012 with uncharted 3). To my denon 2313 via hdmi. No video at all or sound? Please help
You need to tell the PS3 to use the HDMI cable output. To test have you tried connecting the PS3 directly to the TV. Once you have that working then add in the AVR.
Jan 19, 2013 | Denon AVR-2313CI
DENON AVR-1912 PS3 ISSUE
You might just have a handshaking issue between your PS3 and your receiver. See if there are any firmware upgrades for your PS3, Receiver or both. This usually takes care of the problem. If not - your receiver has a 2 or 3 year MFG Warranty. Have it checked out or exchanged.
May 02, 2012 | Denon AVR1912
Denon AVR 1609 7.1 Channel Receiver turns on but i get no sound thru the optical to the tv. what could be wrong?
If you have your video equiptment hooked to your reciever input, then, out to TV, This isn't the best way to go. Of course it depends on what you have for input and output on your TV but, the ideal way to hook your system would be to hook all video equiptment to TV, ie:, cable/sat box, DVD player, etc., to TV via, HDMI, Composite, RCA, etc., then run your digital optical out from TV to reciever. You would use the TV's menu to choose what you watch and would only have one input(audio) to reciever. Some recievers are set up to transfer video, but, it uses more cables, creates more connections, and more room for error.
Jun 13, 2011 | Denon Audio Players & Recorders
I am having troubling hooking up my PS3 to my denon AVR-1907 receiver. I am using the PS3 component inputs and hooking them up to the "VCR" input.
Connect your component cable to the PS3 OUTPUT (there is no input) and connect that to the component IN on your receiver.
Jun 14, 2009 | Denon AVR-1907 Receiver
How do i hook up a PS3 through my denon avr1905?
ONCE YOU CONNECT THE OPTICAL CABLE AT THE DENON, YOU ALSO NEED TO CHECK THE AUDIO SETTING FOR THE INPUT USED AND MAKE SURE OPTICAL IS SELECTED AND LAST ONCE YOU SELECT THE SOURCE INPUT USED TO CONNECT THE PS3 TO THE DENON PRESS THE INPUT MODE BUTTON ON THE FRONT LEFT OF THE DENON UNTIL YOU SEE DISPLAYED THE WORD AUTO, THIS SHOULD GET YOU SOUND AS LOND AS THE PS3 IS OUTPUTING AUDIO OVER THE OPTICAL
Mar 01, 2009 | Denon AVR-1905 Receiver
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
No audio from PS3.
works great, plenty of plug-ins, easy set up, but you get 2 hdmi ins 1 out. hdmis' work great one cable for sound and video but the denon avr588 doesn't accept sound through the hdmi cable.(it's noted in the manual) why not? i don't understand. so you go with optical or coaxial for audio. it works but extra cables.
Dec 28, 2008 | Denon AVR588 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Denon AVR588 Receiver Logo
443 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
