Question about KitchenAid KSRS25IL Side by Side Refrigerator
Icemaker not making ice
My Kitchenaid KSRB25FKSS01 quit making ice yesterday. I removed a stuck cube from the teeth last night, but that didn't fix the problem. I thawed the inlet tube with a blow dryer also. Did the test on the LED light and it comes on and after a few seconds goes out.
  • jjday3 Feb 11, 2009
    I have the same problem. What can I do?
    Problem Solver:
  • 4 Answers
Have you tried to turn off the icemaker and turn it back on? Or maybe even unplug the refrigerator for a few minutes in order for the icemaker to reset?
Posted on Jan 15, 2009
Icemaker on subzero 650 slow
check for water flow at water valve or replace water valve
Dec 09, 2013 | Sub-Zero 650 / O Bottom Freezer...
Model was bought 1/92. Ice cube maker not working although we hear a churning sound that seems to signal something's trying to work! What do you think? KitchenAid KBRP20EMSS Bottom Freezer Refrigerator
Those ice makers get stuck from frozen ice portions. Try feeling around to see if anything in the icemaker is frozen up or any foreign object. Please do this with fridge unplugged. If you can't find any frozen or other obstruction then use the hair dryer to defrost the ice maker. This is only a guess from past experiences. My kids once put pop cicle sticks in the ice maker wanting to make ice cube on a stick. Goodluck Google burdfrenzy
Nov 26, 2010 | KitchenAid KBRP20EMSS Bottom Freezer...
The icemaker on my KitchenAid superba KSBS25in does not work
Their might be an easy fix here. Try a hair dryer. heat the ice maker and dislodge a possible stuck ice cube( a common problem)
More HERE
Dec 15, 2009 | Kitchen Ranges
GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
Jul 04, 2009 | Freezers
Icemaker stuck in 'vacation mode'
Feel inside the ice slots are there any old cubes that have evaporated in time? Take the ice maker out and clean it up and place it back inside to see if it will fill with fresh water. Take a hair dryer and melt the old ice inside the slots and see if it will try to fill. I will wait for a response from you.
KSCS25INWH00 Kitchenaid Parts
APPLIANCE 911
KitchenAid Refrigerator Ice Maker Assembly 2198597
May 06, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Whirlpool ED25TE side by side--ice maker
Check for an ice cube stuck in the teeth of the ice maker that is preventing it to cycle. If this is not the case and it has ice cubes in it then try removing them by hand or you might have to defrost the freezer to free up the ice maker.
Dec 13, 2008 | Whirlpool ED2SHGSM Side by Side...
Ice maker
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Sep 10, 2008 | KitchenAid Superba Architect KSCS25INSS...
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker problem
Apparently lowering the temperature by 5 degrees in the freezer compartment will keep the input water tube from freezing. It is working fine now!
Nov 16, 2007 | KitchenAid KSCS25IN Side by Side...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
253 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
