Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Maytag performa dryer won't run right
tikiman1 on Dec 29, 2008
dryer does not seem to want to start. I have removed belt and drum and the motor turns freely by hand and with electricty. If the dryer does start it only runs for maybe 10 mins and then cuts off, if you wait thirty mins, it might start back on another ten mins. when the dryer won't start it just hums when the start button is pressed, if you hold in start button it seems to kick a breaker or something inside the dryer and then you have to wait for it to "reset" it's self. the heating element comes on and seems to be working fine.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 30, 2008
Not Rated)
onthejob5130
Rank: Guru  Maytag ExpertMaytag Expert
Rating: 86%, 222 votes
bad motor,,should have change it when you had it open,,thats the overload you hearn inside the motor,,when hot it clicks off and when itcool it will run a while than click off...again...need help changing ..
Was this helpful?
Yes
No
Related Problems
OLDER MAYTAG HEAVY DUTY HOME DRYER DRYER WAS WARM AND HAD...
My dryer automatically stops and the door opens even if the...
I turn the timer to x amount of minutes and push to turn it...
The dryer seems to run fine but no heat. It also ran for...
Can you Help with these Dryer problems?
dryer wont start
Solve
dryer wont turn on changed timer door sw and motor did run for a few but then shut off and wont come... (More)
dryer stopped running while drying
Solve
dryer stopped running while drying and now it will not start. Outlet is supplying power.
Iwant to replace the fuse on my...
Solve
Iwant to replace the fuse on my Maytag dryer SDE515DYW. Only problem is I cannot find it!
Dryer won't start. I can hear the...
Solve
Dryer won't start. I can hear the timer but it won't go on???
Sponsored Links
Describe your Dryers problem:
Top Dryer Experts
Rank: Guru Guru
Solutions: 2825
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Dryer Experts
Top Washers & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
