Question about Harman Kardon Sony ICF-CD855V TV/Weather/FM/AM 4 Band CD Clock Radio
Sony ICF-CD855V clock radio no power
I'm trying to locate information on the power supply for the clock radio. The unit has no indication that there is power to the unit and I am trying to find a replacement supply or the power supply output specifications. The power supply plugs into the wall with a low voltage cable to the unit.
Transformer wire that connected to one of the AC terminals was broken. Soldered a jumper wire between the terminal and the transformer. The most difficult part was finding a tool to remove the 3 triangle headed screws from the power supply, ended up making my own tool.
Posted on Dec 31, 2008
Fm reception for weak stations poor. reception on car radio fine.
If there is no FM Antenna connection you can try to move the power cord to different positions and see if you get a better signal. If not then move the unit closer to a window or try various locations that might have better reception.
Nov 21, 2013 | Sony ICF-CDK50 Clock Radio
Hi i am trying to find the output voltage of the mains transforma ? 120v in whats the output
Mains transformer output volts are 12V AC for Sony ICF-CDK50
Circuit location is T901 and part number is 143591722 .... TRANSFORMER, POWER (US, CND)
Hope these info will help you.
Thanks.
Nov 05, 2010 | Sony ICF-CDK50 Clock Radio
No 6V power via power adapter to Sony ICF-SW7600GR
Could be a diode or a capacitor. Where are you located?
Feb 07, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
MY POWER SUPPLY STOP WORKING
300mA is marginal. On CD start unit draws a little over 400mA for about 1/2 second. At moderate CD audio levels the unit draws right at 300 and at full volume 400mA.
Be certain of the polarity and voltage . On the unit I have the wire with the white stripe is negative. If you are using a non-regulated supply, the voltage could be higher than rated. I am using a 9.5 volt non-regulated supply and after input filtering I have 11.5 volts across the input cap, that is rated @16VDC
A non-regulated 12VDC supply will probably exceed this 16VDC
rating.
Measurements taken with Fluke 23 and Simpson 160
Jul 30, 2009 | Sony ICF-CD855VSIL Clock Radio
Power supply
if you are in usa, you need 1-468-809-11 POWER UNIT input ac 110 volt and output 8.5volt dc
and if you are in uk, then
1-468-811-11 POWER UNIT input ac 220 volt and output 8.5 volt dc
bye.
Sep 08, 2008 | Sony ICF-CD855VSIL Clock Radio
Sony Liv Clock Radio, Cd Player
I have a sony dream machine ICF-C18 and had day light saving time and cannot change the time
Please help
Jun 17, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
No power for Sony ICFCD855V Dream Machine.
Power supply seems to be 12 volts. I have ICFCD855V's and the power cords on both broke just past the strain relief on the power supply. That shorted the supply and blew the fuse (1.6 amp). I soldered in a new fuse and the supply (with no load) puts out 12VDC. Since it happened to 2 in my house I can't believe Sony doesn't have a recall on these things
May 10, 2008 | Toshiba Sony ICFCD855V Clock Radio
SOny Clock IC492 looses time
Dont think this model clock accuracy depends upon the supply frequency.
1. I have ICF C 318 with the same specification but works accurately (1 sencond) in 50 Hz.
2. there are some amazone complaints even from US (wherein 60 Hz exists)
3. Dont think a clock designer will depend on supply frequency. (many time, this varies even in a very good power network)
Jul 15, 2007 | Sony ICF-C492 Clock Radio
643 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
