Question about Whirlpool GD5SHAX Side by Side Refrigerator
Freezer quit then noticed fridge side not cooling
Noticed melting water coming from freezer and was not cold no ice build up on tubes and now noticed the fridge side is not very cold cool air is blowing from bottom of fridge where it used to be warm air
air still flows through both the freezer and fridge but not very cold
  • 115 Answers
The relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Posted on Dec 30, 2008
My whirlpool fridge is not working, the freezer is working, I can't understand it. The thermostat inside the fridge seems to be okay, inside the fridge is not even cold. Can you help me. My fridge...
Your cooling comes from the freezer side through cooling tubes to the refrigerator side.
The first thing is to make sure that the evaporator fan is working, because that will blow the cold air into the refrigerator side. If it is working then you probably have an ice build up around the evaporator. You will need to remove the inner rear panel of the freezer to check it.
If there is a lot of ice on the evaporator fins then your defrost circuit is not working. But if you manually defrost the freezer (a hair dryer will speed it up) and make sure the cooling tubes are clean of ice (can feel the air from the hair dryer on refrigerator side) then you will have anywhere from a few days to a few weeks before the ice build up returns.
So you should troubleshoot your defrost circuit and get the parts on order to be ready for the next time.
Jul 15, 2011 | Whirlpool Refrigerators
Suddenly, the temerature of the refrigerator and freezer went up to the point that the ice cubes and ice cream melted. Sounds like the compressor is working. I may have left a door ajar for quite a few...
try unplugging it for a day a so to let the evaporator coil defrost. When left open for long periods the evaporator coil will build too much ice blocking air flow. You might have apuddle of water under the fridge after the melt. -->
c_getProfessional_AskGet_refreshPicture(); if (!window.unique_ord) { unique_ord=Math.random()*10000000000000000;}document.write(''); 817-grey.gif
May 22, 2011 | Kenmore Side by Side Refrigerator
My side by side Fridge has been running at 13 degrees for a few days.,the freezer is normal. We noticed some "ice build up , took the cover off and all the elements etc... were iced over, we have...
This is what is happening. All "frost free" refrigerators are not truly frost free. The cooling comparment elements frost up with moisture from the air. Every 6 or 8 hours or so the fridge shuts down. then . small electric heaters fitted into these cooling elements melt the frost away. The water goes down a tube into what is called a drip pan mounted underneath the fridge. If the drain tube clogs with a piece of paper, or food or algae. The water from the frost melting stays in the pan because the drain is clogged. So each time the fridge defrosts, it builds up ICE not frost and eventually it completely clogs with a block of ice.
The other thing that can happen, is that the timer that controls this cycle fails and the heating elements never turn on. The the fridge then clogs with frost. The fridge will clog with frost if any of the following parts fail. The defrost thermostat which opens up the heater circuit when the coils reach
around 40-50 degrees, the defrost heaters mounted in the cooling coils, or the defrost timer fails.
If your fridge works normally after this, then the drain hole was clogged and you unclogged it. If it gets colder and colder again. Then the timer, defrost thermostat, or the defrost heaters have failed.
Hope this helps. You are welcome to write back to me and tell me what is happening with your fridge. I hope this helps, Best Regards, Mark
Dec 28, 2010 | Refrigerators
Ref side not getting cold, freezer still cold
Hi, Is the Freezer still cold? If so either the Fan (In back of freezer-Remove rear panel) is not working or the vent between freezer and fridge is close (side panel between freezer and fridge) Check either of those should be able to pick which is not working
Jul 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit working and is causing ice build up on the back of the freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge and freezer not getting cold
  • You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
    Len West
Feb 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
423 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
