Question about Samsung CLP 300 Laser Printer
Loud irregular noise from printer during and after printing
It may be due to the half disc handle of the black toner cartridge banging against the front cover. the black toner does not appear to be feeding into the printer properly. It prints in light and dark waves as if it is out of ink, though my cartridge weighed 15 g more than an empty cartridge.
  • r3x3 Jan 20, 2009
    printer makes grinig noise as though plastic wheel gears are slipping, sort of catock-catock-catock-catock-catock-catock-catock-catock-catock-catock-... catock.  Just started and my warentee is about to expire.
    Sergeant:
  • Samsung Expert
  • 406 Answers
This is the common problem of clp 300. you are required to change the black developer. for this you may approach authorised service center.
Posted on Jan 02, 2009
Lexmark c772 when printing it make load Laud noise
Please power off the printer. Remove all the toner cartridges. And then put them back in. Make sure you install the toner cartridges properly. After that power on the printer. Try printing again.
Jul 20, 2012 | Lexmark C772dn Laser Printer
We have a CLP-300 Series A laser printer which we really like. The problem we are having has recently surfaced after we changed the BLACK toner cartridge. There are skips and light area in the printing...
I think you should contact the manufacturer or vendor who sold you the cartridge. The standard warranty is 90 days. I believe that it will prove to be a bad toner/ drum (which are the same thing for this printer.)
Besides that you can do a "half-test". Stop the print job half way by opening a cover during the print process, before it is transfer to the paper and fused. Look at the drum or transfer belt and see whether the defect exists early in the print process.
There may also be a contact problem with the black toner. Check for bent metal on the toner, or chassis that should mate and conduct charge to the toner.
Whit
Item, Inc.
Dec 13, 2010 | Samsung CLP 300 Laser Printer
My hp lasrejet 5000 N does not print on one side? new cartridge installed today.
Two possibilities
1. check to make sure the laser scanner glass is clean (glass is located above the toner cartridge when you take it out. you might need to move a metal cover that covers the glass)
2. clean the transfer roller. (black spongy roller that sits just below the cartridge).
use a lint free cloth
Jul 18, 2010 | HP LaserJet 5000 Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Hp laserjet 1200 series printer with high pitch nose when in printing process. During this loud noise, the roller turns but the paper is not picked up therefore printing does not occur.
noise is caused by the toner cartridge and paper is not going trough because there is a plastic milar clse to the feed roller that is bent,find it and push it towards the inside of printer (is a black or dark brown plastic mylar)
Aug 24, 2009 | HP LaserJet 1200 Printer
LOUD GRINDING NOISE
The black dust is toner. Be carful as it is carcenagenic (dont get it on your skin) you will need to dispose of the leaking toner cartridge and get a new one. also you will need to clean the printer very carfully to get rid of the spilt toner. A combination of spray duster and a toner hoover are the best way. do not use a normal hoover as you will kill it.
It is always possible that you have done serious damage to the printer using a non standard toner cartridge. I would recomend getting a qualified person to give the printer a good service.
Jun 03, 2009 | Sharp AL-1655CS Laser Printer
Color Laserjet 2550 Loud Noise when starting up and printing
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
May 29, 2009 | HP Color LaserJet 2550n printer + HP Color...
VERY LOUD NOISE WHEN PRINTING WITH MY SAMSUNG CLP-300
You all say that the toner cartridge is okay, so it could be the hole OPC Image Drum or the ITB which is the tranfer Belt.
The Tranfer Belt is behind the Image Unit.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
Cannot print
toner cartridge remove than close cover if again that noise its means that heater unit is jammed due to over heating. If printer initialize normally its mean that your toner is jammed.
Jun 24, 2008 | Samsung ML2251N Laser Printer
Loud clattering noise
-Open the Front Cover. -Remove the Toner Cartridge -Remove the Drum Cartridge -Next locate the black gear attached to the end of the Drum and turn it with your fingers. -Check to see if the gear is locked, or difficult to turn. The gear will only turn in one direction. -If the gear won't turn at all, or if it catches while you are turning it, or if you hear the same noise when you turn the gear that you heard when the machine was on, the Drum Cartridge is the cause and will need to be replaced.
Jun 22, 2007 | Xerox WorkCentre XE88 Laser Printer
Samsung CLP 300 Laser Printer Logo
219 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
