Question about Acer NSK8458AN Keyboard
Acer keyboard key function
When I try to get the @ function on the 2 key it comes up with"
  • 6 more comments
  • gkuhn Jan 07, 2009
    I also get a / when I pressed the 3 key. After a little while it came back. Very frustrating though.
  • Anonymous Jan 14, 2009
  • sbalduccio Jan 24, 2009
    how to swich the button for @
  • Anonymous Mar 18, 2009
    Same as the others.....when I want to get the 'at' sign, I get the " symbol. Still have no methods.
  • Anonymous Mar 23, 2009
    exactly the same and its only just come back from acer for repair!
  • Anonymous Apr 20, 2009
    how do i find the "at" button on my acer extensa 5230
  • Anonymous Apr 29, 2009
    when i try to type 'at' i get "
  • Anonymous May 04, 2009
    When i try to use some of the punctuation keys they are not coming out with what is expected for example when i try to type the 'at' sign i get " and when i try to get the pound sign i get # and so on
    How can i fix this ?
  • 3 Answers
Have you tried going into Control Panel; Clock, Language and Region; under Regional and Language options choose change keyboards and other input methods. Then check that you have the correct keyboard for your region: in the UK and the US the @ and the " are in directly opposite places.
Posted on Nov 12, 2010
3 Suggested Answers
  • 2668 Answers
SOURCE: keyboard functions
Your region and language settings are incorrect.
Go to control palel/Regional&Language settings/ use the drop down menu to select the correct region then click on languages tab/details and do the samme. apply and exit.
Posted on Sep 18, 2009
  • 10406 Answers
SOURCE: What key stroke functions do I use for the
Click Start
Click Control Panel
Click Classic View
Click Regional and Language Settings
Switch to use the "US English" keyboard,
instead of the "French" keyboard.
Or, if your keyboard has an 'ALT(ternate) GRA(phic)' key, hold that key down, press the '?' key, and a '?' should be displayed.
Posted on May 30, 2010
Third function keyboard
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key.
The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function.
The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key.
Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop.
Use the drop-down menus on the support page to choose the specific product line and then model of your laptop.
Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop.
Browse down to the section about the functions of the keyboard keys.
Find the sequence of keys you need to press to unlock the function key on your laptop.
Press and hold the function key on the keyboard and then press the other keys required to unlock it.
Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key.
Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys.
5
Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop.
Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
http://us.acer.com/ac/en/US/content/support
Acer Support
Nov 26, 2013 | Acer Computers & Internet
Acer Aspire 5002WLMi Keyboard problem. I somehow did something to my keyboard set up so it is using the secondary options. For example, when I type the letter K, it comes up a 2. L comes up as 3 etc. I...
Try holding the Fn key, usually blue, while pressing the "num lock" key, which is usually above the 7. This should release the number pad function of the keyboard.
Let me know if this doesn't fix the issue!
John Vickers
Sep 18, 2011 | Acer Aspire 5002WLMi Notebook
I pressed some keys on the computer and now when I use the computer keyboard when I type o I get the number 6 and when I time i Iget the number 5. what did I do I am using a different keyboard as I type...
Hi Carol,
It seems that the function key (Fn) on the bottom left of the keyboard is stuck or jam. Try hitting the key multiple times or raise it with your fingers. Then try to press I and O again. Below the is image of the key you need to press and clear the jam from. You can also pat the keyboard/ laptop from at the bottom in case the jam wont clear by pressing the key.
Fig 1 : The function key
Fig 2 : The the shown below have multiple icon, those are activated by pressing Fn (function key)
Regards,
Shrey
Jun 04, 2011 | Acer NSK8458AN Keyboard
When I try to get the @ function on the 2 key it comes up with "
You've probably got the keyboard set to the wrong region: in the US and the UK the @ and " keys are swapped.
In Control Panel, Regional Settings, Language Settings, Keyboard you can change your keyboard to the right region.
Hope this helps.
Nov 11, 2010 | Acer NSK8458AN Keyboard
Click Start
Click Control Panel
Click Classic View
May 30, 2010 | Acer NSK8458AN Keyboard
I have an acer tuba. the keyboard has three symbols on many of its keys. the white subscript is stuck on. example: the o letter key is coming up the number six. how can i revert the key board back to...
try changing thje language back to English in windows and the keyboard to US english ( Control panel)
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Acer NSK8458AN Keyboard
Keyboard functions
Sep 18, 2009 | Acer NSK8458AN Keyboard
Acer aspire 4315 keyboard functions
aspire 4315 key pad problem some keys not working i changed new key bord and again same problem how to solve this please help me
Aug 22, 2008 | Acer Aspire 5100 Notebook
Acer NSK8458AN Keyboard Logo
1,559 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
