Question about Acer 22" X223w LCD Monitor
Acer 22'' monitor display is too wide, square shapes are distorted. How can I make graphics appear normal?
  • 1 more comment
  • 1mwm Dec 29, 2008
    Acer 22" monitor problem:
    I have tried adjusting the screen resolution. It is 1280x1024 (max). Graphics are still distorted.
  • 1mwm Dec 30, 2008
    Acer 22" monitor distortion: None of the buttons on the monitor are for changing the aspect. I see others have the same problem. Changing the display settings in the control panel does not change the distortion. My graphics card came with the computer (HP).
  • 1mwm Jan 03, 2009
    It says right in the Acer documentation that the resolution must be 1680 x 1050. The only way to achieve this is to replace the original card with one capable of that resolution. I now have a Radeon X1300 Pro installed, and it is graphics heaven!
    Scholar:
  • 46 Answers
You need to verify that you are using the monitors default resolution. if you attempt to use a resolution that the monitor can not handle it will cause distortion.
If you send me the model number I can assit you in finding the correct resolution for the monitor.
Posted on Dec 30, 2008
  • 741 Answers
Every monitor has it's what's called "native" resolution. Which bacisally means it is the best it can do. If click on start>control panel>display properties, then find the slide for the resolution and move it all the way to the right. That is the native resolution for your monitor. You can try different resolutions by moving the scale up and down a little as the large screens scale back well. Also don't forget about the buttons on the front or side of the monitor that makes a difference alsol. There's other little things you can try like trying a new cable I've seen work in other threads for this problem who were using DVI. Let me know how it turns out.
Posted on Dec 29, 2008
  • 599 Answers
There are three sets of adjustments available to you... the monitor settings accessed by the buttons on the monitor... find the right aspect ratio there... the others are within the operating system settings for your monitor and graphics card... rt click desktop and then properties and work with settings there under display and thirdly the graphics card may have software to tune and adjust many aspects of the visual experience of the monitor
  • milespeed Dec 30, 2008
    what operating system are you running on your HP? i will try to find walkthrough..and what model?... maybe we can find graphics card software for it
  • Acer Master
  • 13,433 Answers
Hi have you just ran the display optimization wizard? it sometimes messes it up for me. lets check the resolution first
right click on desktop and select properties then settings move the resolution slider and see if things improve remember to press apply ones you moved it.
  • Ekse Dec 29, 2008
    to norrow down possible causes, test the computer with another display and the acer lcd on another computer.
Coloured squares appear on screen
Seems to me that the LCD cables are not properly atached.
Double check all the LCD connections.
Your problem will be solved.
Jul 05, 2010 | Sony VAIO VGN-NR220E/S Notebook PC
How do I adjust the image width on this wide screen? Everything appears distorted and wider than it is. I would like a narrower image.
This is one of the problems with the wide aspect screen. Most images seem to fit best on the older monitors.
You can go into the video properties and choose one the the display types that best display your image. Unfortunately, by taking a normal (to us) image that looked just fine on an older monitor and displaying it on a newer, wide-aspect monitor, you're gonna distort the image or crop it in a way you didn't expect.
My advice is to experiment with the display until you find something you can live with.
Jul 04, 2010 | LG Flatron W2242P-SF 22" Monitor
Settings have been changed.
Change the resolution in your PC control panel/display settings tab.
Jun 08, 2010 | Acer 22" X223w LCD Monitor
Can't adjust reselution
install the device driver for the VGA monitor.....
go to Device Manager, do u c any yellow ? mark in any device there....specificaly for Display Adaptor....
if not they try to update the driver after going to it's properties...
Dec 14, 2009 | Office Equipment & Supplies
I use my computer mainly for graphics. They are
Hi
I assume you have tried right click on desktop, go to properties, settings and experiment with desktop settings.
Cheers cbacer
Aug 11, 2009 | Acer 22" X223w LCD Monitor
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
WIDE SCREEN MONITOR
Better to reinstall windows(Operating System) and drivers.
Thanks
Mar 01, 2008 | HP Compaq Presario V2000 Notebook
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Al1917w lcd monitor resolution problem
I have the same problem! Here's what I did: Go into the Display control panel, go to SETTINGS, click on ADVANCED, and then on the ADAPTER tab, then on LIST ALL MODES. There are several 1400 settings. Try them out and see which one is best for you.
Jul 30, 2007 | Acer AL1917W LCD Monitor
Acer 22" X223w LCD Monitor Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
