Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune model number mah4000aww
I have this particular model and when it comes to the spin cycle it has a hrd time starting and makes like a monaing noise and then it will go and then stop and the clothes are sopping wet when its done and the water isnt draining out but if i take everyhting out it will do the spin cycle fine on an empty drum..
  • smissmarie Jan 01, 2009
    i took the pump out and took the hose off and the big rubber drain thingy from the drum to the pump nothing at all in it pump appears to work fine i was told that it is the bearings in the drum that keep it from spinning because they are worn, but in order to replace them bearings im told that i need to replace the entire outer shell of the drum! 600 dollar part... new unit for that price pretty ridiculous, my first thought was the pump also like i said i took that off first, but that seems to be working right, its just not spinning it out to make for it to be able to drain. make sense??
  • Bill Newberry
    Bill Newberry May 11, 2010
    Here is a copy of the Repair Manual for your Maytag Neptune Washer. It has everything you need to troubleshoot your washer. Read the Manual and see if it helps you out.
    Thanks
    Sergeant:
  • 311 Answers
Its your pump.get at it thru the back.it may be blocked or may have failed.a volt meter will tell you if its getting voltage.if so should drain,make sure on about spin setting to check.ive had to replace the pump on my neptune
Posted on Jan 01, 2009
  • Thomas Malailua
    Thomas Malailua Jan 01, 2009
    gottya,if it was the spin bearings you would see rust and lots of metal shavings.even the tub may have some play init from the frount up/down play.God bless,tom
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune mah4000aww spin cycle
BELT IS LOOSING TENSION CAUSING IT TO SMOKE REPLACE BELT
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Model # MAH4000AWW Neptune Front Load Washer Problem: Door will not lock. All cycles during wash work except the spin cycle.
Clean out your filter after ref. to user's manual. Try some WD40 on the door mechanism (on machine), lock & unlock door 5 or 6 times while machine is off.
May 10, 2008 | Washing Machines
Maytag neptune mah4000aww 53314036yk
Check the solenoid. It may be bad. This allows the water to come in.
May 07, 2008 | Maytag Neptune MDG5500AW Gas Dryer
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH5500B Front Load Washer Logo
673 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
