Question about Bernina Virtuosa 160
Stops Functioning During a simple stitch the machine started to make loud noises as if a belt (on a car) were loose then stopped working completely. The electrical plug was fine, the thread and bobbin fine. Any clues where to begin (continue) the search?
I had the same problem with my jenome, it looks that the motor belt of your machine needs to change. This was the case with my machine.
Posted on Dec 30, 2008
I just worked with my Shark sewing machine and it was fine suddenly it stopped zig zag and start working simple stitches! Can you let me know why it happened? There was no noise or sound of breaking.
There is a spring that got loose from the needle arm that keeps pressure on the arm. It needs to be reattached. Anyway, make sure all of the normal adjustments are set properly. Just one adjustment wrong will cause the machine to only run in a straight stitch. Possibly a button hole or something else. Remove the top of the machine and look down where the needle arm is. The needle arm bracket has got to pull the arm towards the arm using the pressure of an attached spring. This spring is hanging inside the machine from a permanent side bracket. If it isn't there then it has dropped to the bottom of the machine. Anyway, the needle arm must have the sideward pull in order for the machine to produce a zigzag stitch.
Aug 05, 2016 | Sewing Machines
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
With each stitch the machine makes a loud clacking noise and needle broke
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time--needs to be checked at a repair
shop
Sep 10, 2012 | Brother Sewing Machines
I have a Singer 327K that stitches three or four good stitches and then stops completely stitching
it's very possible that when the needle broke the machine went out of time & would have to be retimed at a sewing machine shop
Mar 10, 2012 | Singer Sewing Machines
Bernette Deco 600 makes loud noise after stitching
hi! there,
open needle plate if the shuttle race and the bobbins has been pull out that making noise,or accumulation of thread under bobbins, if nothing there, run machine and check if shuttle race and bobbins are moving,also with the needle if not,there are opening at the bottom of machine try to open if some gears are broken,or belt is slip.
if broken gears there a lot of parts before you can pull out gear, beside the timing order you cannot put back.this should be done by technician expert
in sewing machine.take this to service center.
cheers have a nice day just rate me.
Apr 09, 2009 | Bernina Bernette Deco 600
Sewing Machine Stops
this sounds like its set for zippers check settings!
Dec 09, 2008 | Husqvarna Sewing Machines
Brother XL-4012
ok,,when you press the foot peddle you will hear a continuous noise like a motor running that means its not the foot peddle, if not peddle is dying or motor carbon brushes are worn, this is a simple fix, we just need to narrow it down
Jan 16, 2008 | Sewing Machines
Machine stops and sews in place
sews only one stitch at a time and have to wait a few seconds before it will do this
Dec 16, 2006 | Husqvarna Lily 540 and 550
Sewing Machines Logo
85 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
