Question about Motorola Mobility TracFone® V170 Cellular Phone
I have a motorola trac phone and everytime i try to dial out it says called failed check restriction -34
  • Anonymous Feb 26, 2009
    I have the same problem when receiving calls on my LG Trac phone...but not on all calls - just certain numbers. I guess I'll try tracfone customer service, but not expecting much.
JUST DELETE ALL OR SOME OF YOUR DIALED CALLS
Posted on Jan 21, 2009
2 Suggested Answers
SOURCE: Call restriction
I have the same problem with my Motorola tracfone. After fooling with it for about one hour, I discovered that for some strange reason, if you turn the phone off. When you turn it back on, you have to wait about 8-10 minutes and then all calls go through with no -34 restriction.
Gary
Posted on Feb 25, 2009
Call restriction 34
I have a similar problem with my Samsung on Vodafone, but the "emergency calls only" error message. Solution is to re-boot it by power off and on. Problem appears irregularly, but functions OK once re-booted. If this solves your problem, then I assume that the other error messages are simply the sort of behaviour associated with computers hanging etc.
Feb 21, 2012 | Motorola Mobility TracFone w175 PayAsYouGo...
I try to dial but it says check call restrictions -34
I have the same problem. You have to wait for the bars to show good reception, then dial.
Jul 16, 2009 | Motorola Mobility TracFone w175 PayAsYouGo...
When I try to make a call, my TrakFone Motorola W175 g displays the notice "Phone restriction -34" and the call fails. I also can no longer receive calls.
Your sim card is bad in the phone. That is the most likely problem. Other than that the phone needs restored to factory settings and try again.
Jun 21, 2009 | Motorola Mobility TracFone C139-4 Cellular...
Call restriction
ALL YOU HAVE TO DO IS DELETE SOME OR ALL OF YOUR DIALED CALLS.
Dec 29, 2008 | Motorola Mobility TracFone® V170 Cellular...
Cannot phone Canada
I had the same problem.
The way around this is to dial the number with one of the following codes in front of it:
*67 or *82
Dialing *67+1+(Canadian Phone Number) <SEND> will make the call to Canada, however, your number will not display on the caller's Caller ID display.
Dialing *82+1+(Canadian Phone Number) <SEND> will make the call to Canada, AND your number WILL show up on the caller's Caller ID Display.
I tried it with my Motorola W375 and it works like a charm as of February 13th, 2009.
Dec 08, 2008 | Motorola Mobility W375 Cellular Phone
Call restrictions -34 everytime i try to make call with my cell
Restrictions -34 Is No signal Went outside my house works fine.Found that I had Poor signal in my house
Dec 02, 2008 | Lands Phones
Unable to make and recieve calls
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
Jul 21, 2008 | Motorola Mobility L6 Cellular Phone
Motorola Mobility TracFone® V170 Cellular Phone Logo
1,489 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
