Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
We have a kodak5300 easyshare all-in-one-printer,the photo paper tray was stuck [it was pushed back to far ?] know i got the WHOLE tray out ,how do i put the phototray back in???? Sylvia
    Problem Solver:
  • 12 Answers
That is a bit hard to do.. start by looking at the tray.. on the edge of that paper tray, there should be a latch, that will be your guide and that should come first.. on the printer, check for a whole where the latch go in.. push in the tray as the latch goes in the whole, the tray will be in a tilted position, after the latch is fitted to the whole then press the other side of the tray, then it will snap in.. the paper tray is position around 30degrees..
Posted on Sep 24, 2009
  • 24 Answers
Try to insert the photo tray at the back of the whole paper tray and make sure that the clear cover of the photo tray is lifted upward when you are inserting the photo tray
Posted on Sep 23, 2009
    Scholar:
  • 60 Answers
Put the tray straight in and push the right hand side in first and there is a latch on the left push that and then push the left hand side of the tray in...........hope that works.....:)
Posted on Jun 27, 2009
Paper tray 2 is stuck -- cant move in or out
the paper lifting rack plastic tabs one of them is broken and the metal that is showing is catching on the guide so the lifting rack is not lowering into place, turn the printer around, remove the door that hides the back of the paper tray, grab the paper size tab and pull it out as far as you can, now get a flash light and either a ruller or a long screw driver and push the lifting rack down into the tray flat and then push the tray out of the printer. once this is done you can examine the broken tab on the lifting rack and call hp for a part number, get a whole baggie of the pieces because they break all the time!!! you can use some fabric medical tape to make a quick and temporary repair. but it will ware out and you will have to do it again. good luck.
Microapex Computer Systems and Printer Repair Center
www.microapex.com
Feb 02, 2011 | HP LaserJet 3600n Printer
Cant pick up paper
the dock will not pick up paper lost my manual i tried one piece half full tray and afull tray it worked last time i printed what up
it keeps saing its out of paper
Jan 19, 2010 | Kodak EASYSHARE G610 Thermal Printer
Printer will not print properly, say photo tray not engaged.
take out the photo tray if you can and put it back into its place /
turn off the printer and turn it back on . if it works fine if it does not ,the sensor is bad .
it gives you this message only if the paper try is not inserted properly or it is a false error message .
Aug 10, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I cant print 6x4 pictures
make sure you have photo paper in the small tray and the tray is pushed in the whole way. The green light will come on. Load the paper with the shiny side down.
Jan 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Easyshare 500 printer
Be sure the paper tray is full.  Though not a satisfactory solution, I've found the little steel tab that lifts the paper up to be grabbed by the roller just doesn't lift it far enough.  I keep the paper tray full.  Now I only have the problem if I let the tray get down to only one or two sheets.
Dec 11, 2008 | Kodak EasyShare Photo Printer 500
My kodak easyshare5300 is printing black picture
Hi-
If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
Try this first
Calibrate your printer, then print a demo sheet.
  1. If paper is in the photo paper tray, remove it.
  2. Load photo paper into the photo tray.
    1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
    2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
  3. Calibrate your printer.
    1. Press Menu.
    2. Select Calibrate Printer, then press Start.
    3. Wait for your printer to print the calibration sheet.
    4. Place the calibration sheet face down on the scanner glass.
      • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
      • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
    5. Press Start.
    6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
    7. Remove the calibration sheet from the scanner glass, then press OK.
  4. Print a demo sheet.
    1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
    2. Select Print Demo Page, then press Start.
    3. Wait for the demo sheet to print.
Then call them if issue Persist at these numbers:
In the U.S. and Canada: 1-800-421-6699
In Australia and New Zealand: 1800 793 895
Thanks for using Fixya!
Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper error
It sounds like the photo paper tray has gone in.Lift the paper tray and pull the blue photo paper tray all the way till it stops. Then push it back in till it clicks into place. Try printing again.
Let me know if it works
Jun 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
Kodak 5300 wont print on glossy side of photo paper
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Feb 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Have kodak easyshare g600 printer dock
Here is how I solved this problem. If you pull out the paper tray, you will notice two small, white, push pins under and to the right of the pinch rollers. Dip a cotton swab in isopropyl alcohol and use the swab to push each pin in and out a few times, thus cleaning the pins and the holes that guide them. Give it all a minute to dry and reinstall the paper tray.
Dec 14, 2007 | Kodak EasyShare Color Photo Printer Dock
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
