Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Files on device become ''read only'' locked
My backup removable hard drive now codes all files and folders as ''read only'' and I can not edit, rename, or delete. I can only overwrite. This inhibits what I bought it for. SimpleTech portable hard drive with BOM No. 96200-41001-056 with 250 GB
  • malamasly Dec 30, 2008
    did no good, not fixed
  • needname54 Jan 12, 2009
    My drive also went from reading/writing/moving/deleting to read-only. I can't even change the permissions on any of the files on the drive.
  • 151 Answers
I) i think this type of behaviours speciall due to presence of spware, virus in your system, initially to perform a full system scan on your disk and make sure that this not repeating in near future ...
ii) after do this try to change its mode(read only) by right-click on the folder or file u want to use and at the bottom you have to uncheck read only.........
Thanking youy
M. Sridhar
Posted on Dec 30, 2008
How do i view the backup from my previous computer ? i can see the photos from my iphone and one pdf file, the files from the computer are "protected"
Eortiz, did you try to read the files with a windows PC? Because when you connect the external drive to a PC you should be able to view the files and even be able to change the attributes like read only and hidden.
May 12, 2014 | Hitachi Touro Mobile Portable External 1...
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003 - workaroundissue12
Apr 20, 2013 | Computers & Internet
Can't find back-up folder
You might have to create a folder you can do this by right clicking in the backup destination drive selecting new folder and name it lets say Back Up 2012 for the excercise.
Determine how much space you need.
The first step in backing up your hard drive is to figure out how much space you will need to back up all of your files.
You can do this in a couple of ways.
Find out how large the hard drive is on your computer first to see if you can back up the whole thing. Click on "My Computer," right-click the "C" drive and select "Properties."
This shows the approximate size of your hard drive, how much space is actually taken, plus the space used by your operating system.
If your hard drive size is manageable (the space actually taken), back up the whole thing.
Your second option is to create a file called "Backup" and copy all of your important files into it.
Right-click on the folder once everything is copied over and choose "Properties" to find out the size of the folder.
This is how much space you will need to back up your important files only.
Choose a backup method.
Choose either an external hard drive, data disks (CDs, for example) or use an online backup service.
Plug the flash drive or the External Hard drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
Hope this helps.
Nov 16, 2012 | Maxtor OneTouch 4 500GB External USB 2.0...
Will i loose pictures & other files if i format my pc
Yes you will lose all files when you format.
If you want to save your files but cannot open Windows on your computer then remove the hard drive from your computer and connect this hard drive into an USB hard drive adapter. Plug this adapter and hard drive into the USB port of a working computer, this computer will see this as an external storage device, you can then open the folders on this drive and copy/backup the various folders and files.
After you have copied/backup your files, you can install the hard drive back into your computer to format and reinstall Windows.
Feb 06, 2012 | Lenovo Computers & Internet
How do I manage and delete files on the iomega to make room for new backups?
when you plug in the drive it should mount it self and an external drive you can get to it by clicking on my computer and usually it will be labeled removable disk.
Mar 02, 2011 | Iomega 500GB Prestige USB 2.0 Portable...
Folders missing due to folder lock..? Helllo everyone... i have locked some folders by folder lock...but when i open folder lock those folders doesnt appear in list of locked files + It doesnt shows where...
Check this. I use it, because it's much quicker. If you wish to "read" the contents of the .regfile, simply right-click on it, and choose, "Edit." Just DO NOT edit the file.
After you're satisfied it is safe, double-click on it. Now, right-click on a folder you don't have access to and choose, "Take Ownership."
Apr 05, 2017 | NewSoftwares Folder Lock
My Music folder suddenly deleted all the files in it, but the folder won't delete because it says it's not empty; however, it won't let me open it either. It keeps popping up an Error code 0x80070091: The...
You probably have a disk-drive with some "bad" sectors.
So, when you try to read the sectors that contain the directory for the 'My Music' folder,
that sector cannot be read, and thus Windows reports an "empty" folder.
It's probable that your disk-drive is about to _completely_ fail, not just _partially_.
Make a backup of what files & folders that _can_ be read.
Dec 11, 2010 | Western Digital WD Passport 250GB Portable...
My WD External Hard Drive Went From F To g aND i cANT aCCESS mY mUSIC i hAD bACKED uP, tHERE aRE sTILL fOLDERS oF tHE aRTISTS bUT nO fILES iNSIDE
Open "My Computer".
If you have some other USB device (camera?) connected as the 'F:' drive, then the WD drive, when connected, will become the next-available letter, namely 'G:'.
Run a 'Check-Disk' against the WD drive, to check the integrity of the file-system.
Apr 03, 2010 | Western Digital My Book Essential Edition...
I can't remove U3 launchpad
I have had a similar problem to this one. It is relatively easy to fix. Step 1 - Backup any files that you want to keep from your SanDisk. Do this by going into my computer and clicking on the SanDisk removable hard drive. Drag and drop the files you want onto a folder on your computer. Remember - If you back up everything BE SURE YOU DO NOT BACKUP THE U3 LAUNCHPAD SOFTWARE. Step 2 - Get into your My Computer folder and right click on your SanDisk removable storage device and select format. After you format everything should be removed from the memory stick. Step 3 - Drag and drop the files you backed up back onto your memory stick. Done! Hope that helps.
Mar 16, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Response to your Suggestion re: transferring files to external hard drive
This depends entirely on how the backup program you use works. Usually they will go with whichever file/folder has been edited most recently, so if you edit them on your backup drive, they will not be replaced by the ones on your C drive. It would probably be easier just to edit them on your C drive and let the backup program do all the transferring, though.
Also, if your drive comes with one, you should usually use it, and no, having two would be inadvisable because you would end up with two identical sets of your data on the same drive, which serves no logical purpose.
Hopefully that is a more exact answer!
Dec 22, 2008 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
438 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
