Question about Whirlpool LEQ9858P Electric Dryer
Finding the heating element for a LEQ9508PW0
HOW DO I GET TO THE HEATING ELEMENT? DO I GO THRU THE FRONT OR THE BACK
  • 547 Answers
Go in back
Posted on Feb 24, 2009
How do I fix my toaster?
Probably a burnt out element. See this video if you want to fix it
Jul 22, 2015 | Breville Kitchen Appliances - Others
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Idea as to cost of this and how it works please
The cost of a glue gun varies between $5-$20 for a good one.
The glue gun works based on heat, in the front of the glue gun there is a heating element, once you install the glue cartridge and press the trigger the glue cartridge is pressed thru the heated element who melts the glue forcing it thru the front nozzle
Mar 18, 2015 | Crafts & Hobbies
Testing & replacing a dryer heating element
First you have to determine whether you element is in the front or the back of the machine this is done easiest by looking at the front of the machine and seeingif its one complete piece or two. If its one, the element is in the back, if two its in the front. We'll start if its in the back first. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced. Now if the element is the front everything is the same with the exception of you have to remove the lower portion, usually held on by 3-4 screws located underneath.
Jun 04, 2012 | Dryers
Does not heat
Hello there and thank you for choosing fixya
There are a few reasons why this is happening i have listed the most common items to check listed below
1st is the heating element this is the most common thing that fails
The heating elements are a common problem with dryers not heating and are an easy do-it-yourself repair. On the Newton style dryers, the heating element is located under the tub on the right in a round heater-can. To access it, first remove the front panel by removing the two screws on each side at the bottom of the front panel or if it's a newer model, prize the clips under the front panel. Then pull out the bottom of the front panel until the top clips release.This should release the top so that you can lift it up. Once up, you should see the heater at the back. Checking the heating element is the same for both styles. First disconnect power from dryer then unplug the wires going to the heating element. Next using your ohmmeter , check to see if you have continuity between the terminals on the heating element.
If you don't,have continuity the heating element is bad and needs replacing, if there is continuity the heating element is ok.
Mar 06, 2011 | Maytag MDE308DAYW Electric Dryer
How do i change the heating element.
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Apr 13, 2010 | Amana DLE330RAW Electric Dryer
HAVE DEHYDRATOR THAT DOES NOT HEAT ANYMORE
Take apart the bottom unit that contains the heating element. Hopefully it's put together with phillips screws. Mine are not. I'd have to drill out the brads that are holding it together. Once it's apart, use an Ohmmeter to check the heating element. Be sure to disconnect the fan from the heating element when ohmming out the element. If the element is open electrically, replace it. Good luck in finding a place to purchase a new element.
Sep 12, 2009 | Nesco Gardenmaster Digital Food Dehydrator
Dryer does not heat and continues to run/will not shut itself off
This is probably due to a faulty heating element, something the average do-it-yourselfer can replace. Disconnect the power supply, then refer to the owner's manual for procedures to remove the front panel from your specific model. If your dryer has a toe-kick plate in front, that's all that needs to be removed.
1)Locate the heating element heat shield, a box on the lower right side of the dryer.
2)Using a screwdriver, pull the two screws at the front of the heat shield. Remove the front of the heat shield or, if it is on a hinge, flip it down.
3)Remove the wire leads from the heating element terminals by pulling on the leads. To avoid damaging the wires, do not grab them when you pull off the leads.
4)Remove the holding screw on the side of the heat shield that connects to the heating element.
5)Remove the heating element by sliding it out of the heat-shield box. Install a new heating element and secure it to the heat shield with the holding screw on the side.
6)Reconnect the wire leads to the new heating element by pushing them onto the terminals. Place the heat shield front cover back into position and secure it with the mounting screws.
7)Replace the front panel or toe-kick plate and reconnect the power supply to the dryer.
Aug 28, 2009 | Frigidaire Dryers
Replace the upper heating element
hi E mail me model no can proberly sort it. regwoolleu@uwclub.net
Jun 11, 2009 | Ovens
Ryer not heating
If you have 110v from the timer connection to the element and ground, that is normal. You should have 240v between the two element connections. If you do, and the element is not hot, disconnect the wires from the element and check the continuity of the element. If you don't, check back thru the wiring until you find 240v. This test will show you where the fault is.
May 05, 2009 | Dryers
Whirlpool LEQ9858P Electric Dryer Logo
442 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
